メインコンテンツにスキップ
はじめに
There are many benefits to adding a second hard drive to your laptop such as improved speeds, greater storage space, and less heartache when installing new software. Use this guide to install one using our optical bay hard drive enclosure.
  1. Remove the following ten screws securing the lower case to the upper case:
    • Seven 3 mm Phillips screws.
  2. Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
    • If you don't have a Pentalobe driver, a 1.5 mm flathead screwdriver can be used in a pinch. Be sure the head of your flathead screwdriver fits snugly across two of the five "points" of the screw head before trying to break the screw free, as a loose fit will easily strip the screw head.
    • If the head of your screwdriver fits too loosely, find a bigger bit and file it down until it fits snugly before proceeding.
    • You do not necessarily have to follow steps 3-7 to remove the battery in order to replace the hard drive. However, it is recommended to remove all power sources from electronics before working on them.
    It really depends on how thick the 1.5 mm flathead screwdriver is. I tried a low-cost tool and almost destroyed the screw. So be carefull
    Paul - 返信
    Unfortunately, when I added a second hard drive via these instructions, all went well but Bluetooth is now MIA. Can anyone help?
    Peter Payne - 返信
    I agree...
    I have bought a used MacBook Pro, when problems arise, opening Corps was trying to turn the screw, but with poor quality could not turn a screwdriver, only to ruin the screw. Try to buy ifixit Screwdriver set. Good luck to all and thank you ifixit team for such assistance as ifixit.com. Thank you.
    remjok - 返信
  3. Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
    • Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
    The screws holding my battery were all worn out since an earlier removal. So instead of ruining them even more I put some saran wrap on the tip of my pentalobe driver and gently unscrewed them.
    magnus - 返信
    I have a problem with these screw. They a completly warn and I need some new ones to fix the new Battery.
    Does anyone know which thread it is and which length?
    alexanderleith - 返信
  4. Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
    • Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
  5. Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case. Do not try to completely remove the battery just yet.
    • Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
    • Do not try to completely remove the battery just yet.
  6. Tilt the battery back enough to access the battery cable connector.
    • Tilt the battery back enough to access the battery cable connector.
    • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
    • If you're installing a new battery, you should calibrate it as soon as possible.
  7. Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
    • Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
    • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
    I tried to move the plastic piece, but it seemed risky for someone with no experience like me. It was not hard at all to just peel off the camera cable without messing with the connector, and then, carefully take the optical drive out.
    joaquingoyret - 返信
  8. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  9. Disconnect the camera cable by pulling the male end straight away from its socket.
    • Disconnect the camera cable by pulling the male end straight away from its socket.
    • Pull the connector parallel to the face of the logic board, not straight up.
  10. Peel the camera cable off the adhesive securing it to the optical drive.
    • Peel the camera cable off the adhesive securing it to the optical drive.
  11. This step is only required if you have an anti-glare display. If you have a glossy display, skip this step. Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • This step is only required if you have an anti-glare display. If you have a glossy display, skip this step.
    • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
    • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
  12. This step is only required if you have an anti-glare display. Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
    • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
    • Lift the Bluetooth board/cable retainer assembly out of the upper case.
  13. Use a spudger to pry the optical drive connector straight up off the logic board.
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  14. Remove three 3.5 mm Phillips screws securing the optical drive to the upper case.
    • Remove three 3.5 mm Phillips screws securing the optical drive to the upper case.
  15. Lift the optical drive from its left edge and pull it out of the computer. When reassembling, be careful that the SATA cable doesn't get stuck underneath the logic board.
    • Lift the optical drive from its left edge and pull it out of the computer.
    • When reassembling, be careful that the SATA cable doesn't get stuck underneath the logic board.
  16. Débranchez le connecteur du câble du lecteur optique de celui-ci.
    • Débranchez le connecteur du câble du lecteur optique de celui-ci.
  17. Remove the optical drive cable by pulling it straight away from the optical drive.
    • Remove the optical drive cable by pulling it straight away from the optical drive.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
  18. Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
    • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
  19. Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure. Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
    • Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
    The bay and dvd drive cable at iFixit is $40.00 (Unibody Laptop Dual Drive)
    But for $10 more you can get an external casing that will protect your super drive form MCE (http://store.mcetech.com/Merchant2/merch...) A total of $50 dollars. It is what I used and works great and looks pretty and is guaranteed to protect your superdrive. MCE also gives you a disk with software to patch the DVD Player to work with external dvd drives. So For an extra $10 dollars you get better software functionality and a case for your super drive. It works great.
    Robert Wacker - 返信
    Robert, do you by chance also know where to buy an external drive case to make the old hard disk an external portable hard disk ?
    Nina Nokia -
    Early 2011 MacBook Pro was running slow with its 2TB hard drive running at 5400rpm. The DVD drive was almost never used. The iFixit part allowed me to place the hard drive in the DVD bay and place an SSD drive where the hard drive originally sat. Now the computer fires up almost instantly and runs so much cooler as the 2TB hard drive is only accessed as needed. A stunning transformation for a 7 year old laptop.
    Paul Cline - 返信
  20. Make sure that the hard drive connectors are facing down before placing it into the enclosure. Gently place the hard drive into the enclosure's hard drive slot. While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
    It is not a good idea to put fast SSDs into the optibay. System tries to negotiate at 6 Gbit, but it fails; disk is recognized but it couldn't even be formatted. I've waisted a lot of time to find a reason. After swapping SSD with original mac's HD both work properly, one at 6, another at 3 Gbit
    nicholas - 返信
    Good to know, thanks!
    zondervon -
    No problems here with a Samsung EVO in the optical bay. Only downside that is not really fast (80-90 mb/s) but amazing performances on booting time, shut off and opening programs.
    Mike - 返信
    I have to withdraw my comment. It is NOT a good idea to put a SATAIII SSD in the optical bay. It gives random freezes. Swapping it with a HD is indeed better. Better read/writes too. Only downside is that SMS won't work on the optical bay so treat your baby with care. Also Sleep issues might occur when placing a HD in the optical bay (a total freezing system). I already wasted a HD that was in the optical bay.
    Mike - 返信
    I've replaced the optibay with a samsung 840 pro but can't format it nor copy files (a few files work) to it. Do you suggest putting the HDD in the optibay instead? Did you clone the HDD to the SSD before swapping them? Will my Mac boot from the HDD the first time I boot even though it's in the optibay? I would really appreciate an answer, I've spent too many hours trying to figure it out!
    Carl - 返信
    Also had this same problem. Tried and failed a Samsung firmware upgrade. Ended up send drive back to Amazon.
    Andrew -
    Okay it seems like some models of MacBook Pro have issues with a fast (6Gbit/s) SSD in the optical bay. Even though my Mac says it offers 6Gbit on both bays it simply didn't work in the optical bay. So I switched places between the two drives and everything seems to work. My Mac booted from the old HDD in optical bay automatically and then I cloned it afterwards and changed the startup disk to the new one. As said before, don't put a fast SSD in the optical bay!
    Carl - 返信
    Hello Carl. What have you done after switching places between the two drives? Can you explain it with more details please? I have the HDD in the hard drive place, and an SSD in the optibay, and I have a lot of freeze / beachball. Thanks.
    danielsam55 -
    I'm on a Macbook pro 13" Late 2011.
    danielsam55 -
    I have the startup set to the SSD in the optibay.
    danielsam55 -
    I've already done it. switch the hard drives and reboot, that's all. Working without beachballs XD
    danielsam55 -
    My understanding is that SSDs will work (at 6Gbps) in the optical bay of late-2011 13" MBP models but not in late-2011 15" or 17" models and not in earlier 13" models. Are those of you reporting problems installing on late-2011 13" models (MD313LL/A [2.4Ghz] or MD314LL/A [2.8 GHz])?
    Steve - 返信
    I'm experiencing the same issues with the HDDs in the optical bay. I've tried multiple drives (WD caviar blue 3G and a Seagate 6G) with no luck thus far. I replaced the SATA cable and that didn't help with either drive. My SSD still works fine in the main bay but I would like the extra storage.
    For those of you who got the HDD in the optical bay working, which HDD (brand and model) did you use?
    My MBP is a Late 2011 15" (8.2)
    woestmab - 返信
    My understanding is that SSD in the optibay for 2011 MBPs will only work on the late-2011 13" model (not the 15" or 17"). I can confirm that it works in my late-2011 13" MBP. I have a Samsung EVO 500GB in my optibay (HGST 1TB in the hard drive bay) with no problems at all: negotiated link speed of 6Gbits for both drives and not beach balls or other slowdowns.
    Steve -
    I'm not trying to put an SSD in the optical bay. As I said, I've tried multiple HDDs but none of them seem to work. I know that it's possible to put an HDD in the optical bay because I bought the computer with one in it but it seems that none are recognized. I have tried multiple brands and speeds with no luck. I would like to know which specific model of HDD works in the late 2011 15" optical bay.
    Thanks
    woestmab -
    Many people have this problem and they all had the 2011 MBP model. The SATA controllers are both 6Gb/s on optic drive and HDD from 2012 (mid 2012 anyway). And of course we're talking about the non-retina. The last non-retina came out mid 2012.
    maniajami - 返信
    I just installed a Crucial M200 6 GB/s ssd in a 2012 15" Macbook Pro, working without issues. It seems the 2011 models are problematic.
    Martin G - 返信
    Whats the size of this caddy?
    Looks like no one has any clue. I can see following sizes:
    12.7mm universal
    12.7mm unibody
    9.5mm universal
    9.5mm unibody
    I have a macbook pro mid 2012 non retina
    saran3h.bansal - 返信
  21. Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure. Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
    • Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
    Make sure you have removed the 2 screws at the end of your super driver unit and move it to your NewHD bay with the metal piece eye loop.
    Kamiiyu - 返信
    Normally with the HD enclosure there come a set of screws. use these to screw down the HD in the enclosure since you need to flip it up side down to reinstall it into the MBP
    Bart - 返信
    Here they picture Crucial as their choice, you can also find some great options at Samsung (it is what I installed and it works just as good if not better than the crucial I installed in my wife's iMac. here is their site http://www.samsung.com/us/computer/solid...
    Its just another great option. Also when installing SSDs make sure to enable TRIM support (crashes can and probably will occur if you don't) TRIM enabler is available free and the pro version is $10 http://www.cindori.org/software/trimenab... It is the easiest solution for this issue.
    Robert Wacker - 返信
  22. Use two Phillips #1 screws to secure the drive to its enclosure. Use two Phillips #1 screws to secure the drive to its enclosure.
    • Use two Phillips #1 screws to secure the drive to its enclosure.
    With the particular drive bay adaptor I used, these attachment screws were already fitted to the adaptor but were found at the sides, not underneath. Indeed, the adaptor had no screw holes on the underside.
    jjsanderson - 返信
    At first I couldn't get my machine to even turn on - thought it was the battery connector, but in the end I just had to reset the SMC. (http://support.apple.com/kb/ht3964 - see "Resetting the SMC on portables with a battery you should not remove on your own").
    mainframe - 返信
  23. Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
    • Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
    I have the drive installed with this bay, but the drive does not appear in the Disk Utility. I see a 'Nvidia MCP79 AHCI' in the system information, but no drive listed with it. Is there some special driver needed to get the MCP to see the drive?
    toddfletcher - 返信
    Replaced the optical with hdd, as well as replaced the hard drive with an ssd. Now I get the circle with a line through it. But, when I hold the option key down, it gives me both hard drives, PLUS, the thumb drive I have in the USB port with a Mountain Lion installer. It even shows the recovery disks, but gives me the circle with the line when I choose one. Any help is appreciated.
    claude - 返信
    Mate,
    My mbp shipped with OS 10.8, and I had upgraded twice to 10.10
    I've a 10.7 USB which upgraded my old MBP.
    My plan today was to boot with my new ssd, my time machine back up and the Lion usb plugged in.
    I would then click on the Lion usb, and tell it to put the OS and time machine back up on the ssd.
    So I help down ALT and when it started it gave me the options of the usual Mac internal or the Lion USB.
    I clicked Lion, but instead of taking me to the install options (Disk utility, restore from time machine etc etc) it gave me that grey circle with a diagonal line through it. The no entry sign - grey on grey - that I think you have.
    Some googling said that it is because I was trying to usb a 10.7 install on a MBP that shipped 10.8
    You can't go back, apparently.
    So if any of the OSs are older than the mac you got, you will get this error. The grey in grey no entry.
    I just cloned my HDD to my ssd (Carbon copy cloner free 30 day trial) using an external stat-usb3 wire and all is good.
    Rory -
    it does not recognize the hard drive in the enclosure, what should i do?
    elvin00 - 返信
    simple question, how do I use the removed drive to play a DVD? Why don't I just use digital media...yadayada...I know. I'm currently in the hospital, did this drive swap for busy work. The littles want to watch an old DVD and I can't solve the issue.
    gator6 - 返信
    This will give you instructions on how to get your DVD player to work in an external enclosure: http://macenstein.com/default/2011/07/ho...
    Steve -
    I have a 17" Macbook Pro6,1 unibody with an Intel Core i5, 2.53GHz. I was successful installing a 250GB SSD in the DVD bay, and I'm able to boot from it. I did this by first installing OS X 10.9.4 on the SSD mounted into an external HD case, testing the system to see if it would boot up into the SSD, then installing the SSD and carrier in the DVD drive bay. The system now boots up from the SSD with no problems. If you are having installation problems, I recommend trying this method.
    roger hall - 返信
    This is really for step 23: reassembly
    You can not get the orginal screws back in to hold the new optical drive replacement in place because there is a black plastic filler running along the front edge of the part. There is no place for the screw head to go. I had to remove some of the plastic to get the machine reassembled. Whoever tested this overlooked what I think is a major problem. How many macbook pros are out there with only one (maybe two if you're lucky) screw holding this thing in place?
    I got extra screws and have no idea why. The bits included in the kit are poor and don't work on most of the screws. I had to use my own tools instead.
    eetech - 返信
    Hi,
    I'm using a 13' MBP mid 2010 and I just swapped my HDD for a SSD. Al works perfectly fine!
    So i bought the unibody laptop dual drive (from iFixit) and replaced the optical drive for the original HDD from my MBP. The installation with this guide went perfectly, however, the HDD is not recognized in disk utility.
    I put the old HDD back on the original HDD bay, the HDD boots and works. I placed back the optical drive in the optical bay, also works. But when i put the HDD in the unibody laptop dual drive (iFixit), it is not recognized via the USB-port(however, the HDD starts spinning) or when installed in the optical bay.
    So i think there is a software issue where my MBP does not recognize a HDD in the optical bay. Is there a way to force the OS to look for storage/HDD via the optical bay STATA cable?
    All help is welcome!
    Thanks,
    Leon
    Leon - 返信
    Leon: did you fix your issue? I'm facing the same problem.
    Rafael Borges -
    No, afraid not..
    Leon -
    also having the same problem, not recognizing second hdd
    cmaizan -
    Same here: installed original hdd in optical bay and it won't mount. Tried it using the sata cable on different computer, and the drive spins, but doesn't mount either. Would love to get a fix (or at least an explanation) for this. The whole point was to add extra storage, but so far, no dice.
    Simon Abrams -
    Did you ever find a solution?
    I installed mine, but the ssd I'm using was a bootable usb running Yosemite, and now that I plugged it in, I'm getting a circle with the slash through it when I try to boot to it, and I can't unmount it or reformat it from the recovery Disk Utility or in Mountain Lion on the stock hdd still inside.
    drguttridge -
    Same issue here unfortunately... new SSD in primary slot is recognized fine and allowed me to install OS X with no issues from USB. However, both during the install when booting from USB and post-install within the full El Capitan OS, I simply do not see any '2nd' hard drive in the system - for the record I just reused the same 500GB HDD that came with my MBP; and I ran the exhaustive System Profiler tests prior to doing any work to ensure I'd have no HW issues/surprises. Sure enough,. I can hear the mechanical drive churning as the power runs to it, so I know it's hooked up okay. For some reason the drive just isn't being recognized by the Mac OS. Hoping someone can help me resolve this so I don't feel bad about spending the [extra] money on the iFixit enclosure system vs. one of the cheaper alternatives I found online, sigh... Any help would be much appreciated, thanks!
    Brian M -
    Figured I'd reply to my own message just above for those interested or following my situation. The 'churning' I heard was actually the left fan inside the system, which I managed to disassemble so I could lubricate the sleeve bearing with a touch of mineral oil - now it's as quiet as ever and works great. Also, I ordered a replacement optical SATA adapter cable from iFixit and this resolved my issue of accessing the hard drive moved to the optical slot inside the dual drive enclosure. Long story short - all of my issues are resolved thanks to some disassembly/repair work and new parts from iFixit!
    Brian M -
    Same problem happens, i don’t know how to fix that as well. Anyone has any idea? Thanks
    jimmychan1007 -
    Hi!
    I followed the tutorial and everything works fine when I use an HDD 320 go but when I use the new HDD I bought which is an Hitachi 1T 7200T 2.5 P I have some trouble. The disk utily takes a long time to recognize the new hard drive and then starts not responding.
    I tought my new HDD might be broken but when I use it with an external portable HDD Enclosure it works fine...
    Any ideas?
    Thanks!
    Julie
    Julie Odeursa - 返信
    I do believe the max size HDD is a 750GB. 1TB might be too big. Though the ONLY place I found this stated was on iFixit. No where else.
    zondervon -
    I just have finished installing second SSD to my MBP (unibody 15` 2010).
    First one was changed like one year ago. Samsung 500GB SSD. It is in my HDD bay and I'm running system from it.
    Today I put a new Samsung 1TB 850 Evo 1 SSD in to my optic bay.
    I encounter problem with SSD not recognized by Finder.
    But It was recognized by Disk Utility.
    What I did was I erase new SSD by Disk Utility. Then the new partition was created and now It has been seen by Finder.
    So If you see it in Disk Utility just erased it.
    Some extra info in under this link--> https://discussions.apple.com/docs/DOC-4...
    Wish you all luck :)
    rybafly - 返信
    Hi all,
    I did this and all seemed to be working fine, both drives showed up and all was good then about 20 minutes later i got a message saying that "the drive had been ejected incorrectly" or something like that. The drives have now disappeared from finder and Disk Utility. I took the SSD out of the superdrive caddy and put it in an external USB3 caddy, it's working fine. I even left this connected over night (all OK). This morning i put the SSD back into my Late 2011 MacBook and the same thing happened, 20ish minutes and then the eject message... Have i missed something?
    Any help would be very much appreciated.
    Steven Vacher - 返信
    Dear iFixit
    I changed my Hdd with an ssd using this guide. My hdd is now in a caddy where the optical drive used to be.
    I can see my original drive ( Toshiba 500GB ) in the disk utility-app, but i can't reach my data on it.
    When i take it out of the caddy again and put it in a external Hdd case, i can read it perfectly fine.
    So there is nothing wrong with the hdd or the connection.
    Is this a problem i can fix with software?
    Thx for the help!
    Jonas Lesage - 返信
    Those were Phillips #00 in my case, not #0, on the small metal mounting bracket.
    Oliver Creighton - 返信
  24. Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable. Align the cable's SATA connector with the drive's port and plug in securely. Plug the USB connector into your laptop and your optical drive is ready for use.
    • Don't ditch that drive! You can still use your optical drive externally with the help of our SATA Optical Drive USB Cable.
    • Align the cable's SATA connector with the drive's port and plug in securely.
    • Plug the USB connector into your laptop and your optical drive is ready for use.
    There is a small metal button in the front of the drive and you can use that to eject the drive if you were wondering.
    Joseph Landry - 返信
    my drive’s connector is nothing like that, and I’m wondering is it possible to connect it to another computer?
    grantdavis - 返信
    Outstanding instructions!!
    syellon - 返信
まとめ
48 の人々がこのガイドを完成させました。
Brittany McCrigler
メンバー登録日: 2012年03月05日
81,845 ポイント
132のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
98 メンバー
8,966のガイドは作成済み
コメント1件
Well, actually a question.
Reading the parts list for this project, I find FOUR different drives -- 2 hybrid, 2 SSD -- that I will be installing. Is that correct, or have I misinterpreted something about these components?
Nicky - 返信
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 51
今までの合計 20,749
