メインコンテンツにスキップ
Install iJDMTOY HID Headlights
必要な工具と部品
  1. Install iJDMTOY HID Headlights, HID Headlight Bulb: 手順 1、 2の画像 1 Install iJDMTOY HID Headlights, HID Headlight Bulb: 手順 1、 2の画像 2
    • Open the hood and then locate the back of the headlights.
  2. Install iJDMTOY HID Headlights: 手順 2、 1の画像 1
    • Remove the cap covers behind the headlights.
  3. Install iJDMTOY HID Headlights: 手順 3、 2の画像 1 Install iJDMTOY HID Headlights: 手順 3、 2の画像 2
    • Once you can see the OEM headlight bulb, twist and unlock to take it out.
  4. Install iJDMTOY HID Headlights: 手順 4、 2の画像 1 Install iJDMTOY HID Headlights: 手順 4、 2の画像 2
    • For a lot of D1S and D3S, there's a bulb retainer, which you will need to remove.
  5. Install iJDMTOY HID Headlights: 手順 5、 1の画像 1
    • Examine your stock bulb. Make sure that the labeling on the OEM bulb is the same as the new HID bulb.
    • For example, this particular vehicle uses D1S stock bulb. You'll need to make sure that the HID replacement bulb is also labeled as D1S.
    • D1S and D3S are not interchangeable, so if you find that the labeling does not match, you will need to exchange for the correct size.
  6. Install iJDMTOY HID Headlights: 手順 6、 3の画像 1 Install iJDMTOY HID Headlights: 手順 6、 3の画像 2 Install iJDMTOY HID Headlights: 手順 6、 3の画像 3
    • Take a look at the pins inside of the bulb. You can see that there is 1 pin by itself, a gap, and then 2 pins together. When you connect the new HID headlight bulb to the adapter, the pin direction needs to match! Look closely at the adapter and you will see numbers denoting slots 1,2, and 4.
    • Make sure that the pins on the HID headlight bulb and the pin slots on the adapter directly match prior to connection. If you connect the HID headlight bulb and the adapter the wrong way, the connection will still go in, but the incorrect insert WILL cause the bulb to have issues such as not lighting up, flickering, or damage to your vehicle.
    • So before connecting the HID headlight bulb to the adapter, make sure that the pins from the HID headlight bulb match the corresponding open slots on the adapter.
  7. Install iJDMTOY HID Headlights: 手順 7、 2の画像 1 Install iJDMTOY HID Headlights: 手順 7、 2の画像 2
    • Now you can install the HID headlight bulb back with the original retainer and then insert it back the same way you removed the OEM bulb.
  8. Install iJDMTOY HID Headlights: 手順 8、 2の画像 1 Install iJDMTOY HID Headlights: 手順 8、 2の画像 2
    • Put all the components back in place and enjoy your new HID headlights.
終わりに
As you can see, it's very straight forward to install. Installing this iJDMTOY HID Replacement Bulb will give you light when yours burnt out.
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Eric Wu
メンバー登録日: 01/21/15
3,357 ポイント
23のガイドは作成済み
10 件のコメント
I am really impressed with your guide eric. As most people don't know how to change a light bulb. Well through your guide I am sure many people and companies like error free article writing services must have learned a lot from you. Well, keep sharing new guides with us.
alexa chris - 返信
I've heard that Samplius.com is a reliable source for online shopping. Has anyone else had any experience with the website? Is Samplius.com reliable?
Iron Dowman - 返信
If essay writing has always been one of the most challenging assignments for you, and choosing a trusted essay writing service has been even more complicated undertaking, ***https://www.writingpapersucks.com/ess... is the platform to consider.
NicolasS Samer - 返信
Regardless of your reason for needing political science essay https://essaysforme.com/write-my-politic...y writing help, we are here with reliable experts who work on assignments at even the toughest levels.nstead of rushing and delivering a substandard task to your institution, it's best to give it to one of our professionals. For one, they will provide you with a quality essay in return, while you put more focus into your other tasks. Secondly, you will get a perfect model of what your task should look like, which you can use for your future assignments!
hopkinsm - 返信
There are many popular Tower Defense games. Some of the best games include Bloons TD 6, Kingdom Rush Vengeance, Plants vs Zombies, and our web site has them all.
Duncan Jones - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 49
今までの合計 3,319
