メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Install iJDMTOY Front Bumper Tow Hook License Plate Adapter
必要な工具と部品
  1. Install iJDMTOY Front Bumper Tow Hook License Plate Adapter, Before we get started: 手順 1、 1の画像 1
    • If you compare the stock tow hook and the stick from the license plate mount, you will notice that the threading is a little different.
    • This is actually because the stock tow hook is made with steel from a mold and the license plate mounting stick is made with CNC machinery.
    • CNC machinery = computerized machine used to carve aluminum
    FixBotに聞いてみる
    コメントを追加
  2. Install iJDMTOY Front Bumper Tow Hook License Plate Adapter, Removing tow hole cover: 手順 2、 1の画像 1
    • Remove tow hole cover
    • Every car is different! Some cars require a pry tool. Others you can simply use your finger to push the corner.
    FixBotに聞いてみる
    コメントを追加
  3. Install iJDMTOY Front Bumper Tow Hook License Plate Adapter, Insert stick: 手順 3、 1の画像 1
    • Insert license plate mount stick
    • Make sure stick is inserted in so it's perpendicular to the opening
    • Tip! There is only one point where the threading can latch on. Keep turning the license plate mount stick clockwise until it latches. Do not tilt the stick in any way
    • The tow hole adapter stick does not have to be extremely tight, just adequately secured would be fine. You can use a wrench if you feel like you cannot get enough grip with your fingers.
    FixBotに聞いてみる
    コメントを追加
  4. Install iJDMTOY Front Bumper Tow Hook License Plate Adapter, Mount license plate: 手順 4、 2の画像 1 Install iJDMTOY Front Bumper Tow Hook License Plate Adapter, Mount license plate: 手順 4、 2の画像 2
    • Mount license plate. Use one of the 1/4" nuts that's included in the package. Insert the screw to mount them together.
    • This increases the friction between the license plate mount stick and the plate to prevent spinning.
    • The adapter license plate is designed with curves so you can tilt it to make sure it's parallel with the car bumper.
    • The bolts are specially designed to use the hex tool included in the package so that the license plate adapter is difficult to steal once it's installed. Use the hex tool and wrench to secure.
    FixBotに聞いてみる
    コメントを追加
  5. Install iJDMTOY Front Bumper Tow Hook License Plate Adapter: 手順 5、 2の画像 1 Install iJDMTOY Front Bumper Tow Hook License Plate Adapter: 手順 5、 2の画像 2
    • If you feel that the license plate is not secure enough, you can use an extra nut and screw included in the package.
    • Most people only secure their license plate from the top, so you will definitely have more than enough nuts and screws.
    FixBotに聞いてみる
    コメントを追加
終わりに
Not only does installing this front bumper license plate mounting bracket look great, but you also don't have to worry about getting a ticket!
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Eric Wu
メンバー登録日: 01/21/15
3,600 ポイント
23のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 10
過去 30 日: 87
今までの合計 8,983
