メインコンテンツにスキップ
Install an Extension Cord Female Plug
必要な工具と部品
  1. Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: 手順 1、 3の画像 1 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: 手順 1、 3の画像 2 Install an Extension Cord Female Plug, Install an Extension Cord Female Plug: 手順 1、 3の画像 3
    • Install an Extension Cord Female Plug is a relatively simple process that anyone can do at home. This is the cord that we will repair.
    • Disconnect the cable before carrying out any repair work.
    • Use a utility knife to cleanly cut from the middle and around the cable.
  2. Install an Extension Cord Female Plug: 手順 2、 3の画像 1 Install an Extension Cord Female Plug: 手順 2、 3の画像 2 Install an Extension Cord Female Plug: 手順 2、 3の画像 3
    • Use wire strippers to remove about 2 cm from the inner wires
  3. Install an Extension Cord Female Plug: 手順 3、 2の画像 1 Install an Extension Cord Female Plug: 手順 3、 2の画像 2
    • Make sure you put the bottom cover of the female plug.
  4. Install an Extension Cord Female Plug: 手順 4、 3の画像 1 Install an Extension Cord Female Plug: 手順 4、 3の画像 2 Install an Extension Cord Female Plug: 手順 4、 3の画像 3
    • The green screw is for the (green wire), the gold screw is for the (black wire), and the silver screw is for the (white wire).
    • For green wire.
    • For black wire
    • For white wire.
    • Now when you have each wire inside the hole you tighten the three screws.
  5. Install an Extension Cord Female Plug: 手順 5、 3の画像 1 Install an Extension Cord Female Plug: 手順 5、 3の画像 2 Install an Extension Cord Female Plug: 手順 5、 3の画像 3
    • Electrical tape is optional.
    • Need to make sure both of the parts are lined up in the same directions.
    • Push both parts together and you would see the screws pop up.
  6. Install an Extension Cord Female Plug: 手順 6、 3の画像 1 Install an Extension Cord Female Plug: 手順 6、 3の画像 2 Install an Extension Cord Female Plug: 手順 6、 3の画像 3
    • Tightening the top three screws.
    • Also, need to tighten the two bottom screws.
    • Make sure you have one or two fingers in the back of the two screws so they pop up.
  7. Install an Extension Cord Female Plug: 手順 7、 1の画像 1
    • Test out.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Steven Quintero
メンバー登録日: 10/23/23
172 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 5-20, Kershman Fall 2023 CSU Los Angeles, Team 5-20, Kershman Fall 2023人のメンバー
CSULA-KERSHMAN-F23S5G20
1 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 27
過去 30 日: 97
今までの合計 1,326
