メインコンテンツにスキップ
Insignia Sport NS-4V17 Front Case Cover Replacement
必要な工具と部品
  1. Insignia Sport NS-4V17 Front Case Cover Replacement, Battery: 手順 1、 1の画像 1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Front Case Cover Replacement: 手順 2、 2の画像 1 Insignia Sport NS-4V17 Front Case Cover Replacement: 手順 2、 2の画像 2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Front Case Cover Replacement: 手順 3、 1の画像 1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Front Case Cover Replacement: 手順 4、 1の画像 1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Front Case Cover Replacement, Front Case Cover: 手順 5、 2の画像 1 Insignia Sport NS-4V17 Front Case Cover Replacement, Front Case Cover: 手順 5、 2の画像 2
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Front Case Cover Replacement: 手順 6、 1の画像 1
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Front Case Cover Replacement: 手順 7、 3の画像 1 Insignia Sport NS-4V17 Front Case Cover Replacement: 手順 7、 3の画像 2 Insignia Sport NS-4V17 Front Case Cover Replacement: 手順 7、 3の画像 3
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Front Case Cover Replacement: 手順 8、 1の画像 1
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Wesley Ballar
メンバー登録日: 04/18/13
88 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 12-36, Amido Spring 2013 Cal Poly, Team 12-36, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S12G36
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 8
今までの合計 355
