メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The Insignia 2-in-1 stick vacuum power button can suddenly stop working or become jammed. In either case, use this guide to fix or replace the power button.
パーツ
パーツは指定されていません。
  1. Remove the four 12mm Phillips screws , and the one large 32mm Phillips head bolt from the vacuum handle. Pull up on the back cover of the vacuum handle and remove it. Pull up on the back cover of the vacuum handle and remove it.
    • Remove the four 12mm Phillips screws , and the one large 32mm Phillips head bolt from the vacuum handle.
    • Pull up on the back cover of the vacuum handle and remove it.
  2. Remove the two 10mm Phillips #2  screws on the back of the green printed circuit board. If the circuit board needs to be replaced, locate where the two white wires are soldered to the board, and de-solder the connection. If the circuit board needs to be replaced, locate where the two white wires are soldered to the board, and de-solder the connection.
    • Remove the two 10mm Phillips #2 screws on the back of the green printed circuit board.
    • If the circuit board needs to be replaced, locate where the two white wires are soldered to the board, and de-solder the connection.
終わりに
Thibaut Pillot
メンバー登録日: 2018年02月15日
434 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S16-G3, Boczar Spring 2018 USF Tampa, Team S16-G3, Boczar Spring 2018人のメンバー
USFT-BOCZAR-S18S16G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 67
