はじめに
This guide will take you through the process of replacing the Tip-Over Safety Switch inside the Insignia NS-HTMC01-B.
必要な工具と部品
Flip the device over so the back panel faces up.
Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
Use a Phillips #0 screwdriver to remove the 1.3mm screw on the black rectangle above the Tip-Over Safety Switch.
終わりに
