はじめに
The motherboard is connected to the LCD screen and daughterboard. It is important to unscrew and disconnect the LCD and daughterboard before removing the motherboard so as not to damage these components.
必要な工具と部品
Be sure the radio is turned off by pressing the red power button.
Or, if using the charger, remove the power cord.
Using the J1 Philip's head screwdriver, remove the 4 screws from the back side of the radio.
Using the J1 Philip's head screwdriver, remove the 6 screws holding the central circuit board and the upper right circuit board to the panel.
3 の人々がこのガイドを完成させました。
コメント 1 件
Hi Josh, It seems like the nut attached to the small bolt holding the antenna has come loose. I’ve tried my best to remove the panel, but to no avail. My Insignia HD has a little different configuration then the one you posted, and has only TWO phillips screws near the top. Any suggestions on how to remove the panel? Thanks, <michaelk29@hotmail.com>
Michael K. - 返信
