メインコンテンツにスキップ
Insignia NS-F12R6-SS Oscillation Arm Replacement
必要な工具と部品
  1. Insignia NS-F12R6-SS Oscillation Arm Replacement, Front Cage: 手順 1、 2の画像 1 Insignia NS-F12R6-SS Oscillation Arm Replacement, Front Cage: 手順 1、 2の画像 2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 2、 1の画像 1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 3、 1の画像 1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Oscillation Arm Replacement, Fan Blade: 手順 4、 1の画像 1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 5、 1の画像 1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Oscillation Arm Replacement, Back Cage: 手順 6、 1の画像 1
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 7、 1の画像 1
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Button: 手順 8、 2の画像 1 Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Button: 手順 8、 2の画像 2
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 9、 1の画像 1
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Oscillation Arm Replacement, Motor Housing: 手順 10、 1の画像 1
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 11、 1の画像 1
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 12、 2の画像 1 Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 12、 2の画像 2
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 13、 1の画像 1
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 14、 2の画像 1 Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 14、 2の画像 2
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 15、 1の画像 1
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 16、 1の画像 1
    • Remove the small piece of paper hanging on the power button.
  17. Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Arm: 手順 17、 2の画像 1 Insignia NS-F12R6-SS Oscillation Arm Replacement, Oscillation Arm: 手順 17、 2の画像 2
    • Using a Phillips #3 screwdriver, unscrew the the 16 mm long screw fastening the oscillation arm to the lower oscillation gear screw.
  18. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 18、 2の画像 1 Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 18、 2の画像 2
    • Using a Phillips #3 screwdriver, unscrew and remove the 4 mm long bolt on the front face of the base that fastens the motor assembly to the base bolt.
  19. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 19、 1の画像 1
    • Remove the fan motor assembly from the base.
  20. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 20、 2の画像 1 Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 20、 2の画像 2
    • Using a Phillips #3 screwdriver, unscrew the 15 mm long bolt fastening the oscillation arm to the fan base bolt.
  21. Insignia NS-F12R6-SS Oscillation Arm Replacement: 手順 21、 1の画像 1
    • Remove the oscillation arm.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Hank
メンバー登録日: 09/17/18
1,091 ポイント
8のガイドは作成済み
チーム
CSU Fullerton, Team S2-G1, Bruce Fall 2018 CSU Fullerton, Team S2-G1, Bruce Fall 2018人のメンバー
CSUF-BRUCE-F18S2G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 397
