この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
In order to access the back of the fan cage and the motor housing, the fan blades must be removed.
必要な工具と部品
Unplug your fan.
Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
もう少しです!
終わりに
