はじめに
In order to access the back of the fan cage and the motor housing, the fan blades must be removed.
ツール
パーツ
パーツは指定されていません。
Unplug your fan.
Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
もう少しです!
終わりに
