Carefully lift the outer case up, starting from the back.
Removing the outer case may require some force, and you will need to get the case into an angled position compared to the rest of the DVD player before it can be completely separated.
Unhook the 4 hooks on the main casing.
There is one hook on the top of the casing, one on the bottom, and one on each side.
These hooks are brittle and can easily break.
Remove the central 7 mm screw holding the motherboard in place.
Be sure to ground yourself before manipulating the motherboard. A static shock could render one or more components on the motherboard useless.
Keeping the 8-pin connector as straight as possible, lift the motherboard out of case.
You may need to bend the side of the case slightly to give the motherboard room to be lifted out.
Disconnect the white cables connected to the optical drive from the A/V board using your fingers.
Be careful when removing the cables on the A/V board. Don't put too much pressure on the wires or the wires could be damaged.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
