この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If there are major problems with your Insignia NS-D160A14's functionality, it could be due to a faulty motherboard. This short guide will teach you how to remove the motherboard so it can be replaced. The process is very easy, so let's get started!
必要な工具と部品
Unhook the 4 hooks on the main casing.
There is one hook on the top of the casing, one on the bottom, and one on each side.
ある他の人がこのガイドを完成しました。
