メインコンテンツにスキップ
Insignia NS-CSPBTHOL-R Battery Replacement
必要な工具と部品
  1. Insignia NS-CSPBTHOL-R Battery Replacement, Battery: 手順 1、 1の画像 1
    • Push the Spudger into the crevice between the grated panel of the speaker and the base of the speaker.
    • Angle the spudger to create a separation between the grate and the base.
  2. Insignia NS-CSPBTHOL-R Battery Replacement: 手順 2、 1の画像 1
    • Slide the spudger along the separation between the grate and the base of the speaker to loosen the grate. Do this to the entire perimeter of the speaker.
  3. Insignia NS-CSPBTHOL-R Battery Replacement: 手順 3、 2の画像 1 Insignia NS-CSPBTHOL-R Battery Replacement: 手順 3、 2の画像 2
    • Pull the grated panel off.
  4. Insignia NS-CSPBTHOL-R Battery Replacement: 手順 4、 2の画像 1 Insignia NS-CSPBTHOL-R Battery Replacement: 手順 4、 2の画像 2
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  5. Insignia NS-CSPBTHOL-R Battery Replacement: 手順 5、 2の画像 1 Insignia NS-CSPBTHOL-R Battery Replacement: 手順 5、 2の画像 2
    • Push the spudger into the crevice between the base and the face of the speaker and create a separation.
    • Slide the spudger along the entire perimeter and gently pull off the face of the speaker.
    • The two parts are connected by wires, do not rip them apart.
  6. Insignia NS-CSPBTHOL-R Battery Replacement: 手順 6、 1の画像 1
    • Use the spudger to release the battery by sliding it underneath the battery to create a separation.
    • Remove the battery.
  7. Insignia NS-CSPBTHOL-R Battery Replacement: 手順 7、 2の画像 1 Insignia NS-CSPBTHOL-R Battery Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Pull the motherboard from the base of the speaker.
    • Using tweezers, squeeze and pull on the white plastic clip that connects the battery wires to the motherboard.
    • Unclip the battery from the motherboard.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Judith Villegas
メンバー登録日: 02/15/17
312 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 12-6, Eyestone Spring 2017 USF Tampa, Team 12-6, Eyestone Spring 2017人のメンバー
USFT-EYESTONE-S17S12G6
3 メンバー
4のガイドは作成済み
4 件のコメント
excellent, was able to make my Insignia speaker work, which didn’t work for years. The battery had been good. removing and reassembling made the unit work!
Uthayaraj - 返信
What type of battery does it use?
Michelle McFadden - 返信
Did you ever find out what battery it takes?
Steve Skinner -
I found out the correct replacement battery is 18650, 3.7V/2000mAH
Steve Skinner -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 17
今までの合計 2,313
