メインコンテンツにスキップ
Insignia NS-CLIP02 Speaker replacement and troubleshooting
必要な工具と部品
  1. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Motherboard: 手順 1、 1の画像 1
    • Set the clock radio on the work space so the bottom of the device is showing.
  2. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 2、 2の画像 1 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 2、 2の画像 2
    • Use a metal spudger to peel back the adhesive sticker on the bottom of the clock.
    • You should see a single screw beneath the sticker.
  3. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 3、 2の画像 1 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 3、 2の画像 2
    • Using a plastic opening tool, peel off the adhesive gel stoppers.
  4. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 4、 1の画像 1
    • Use a Phillips screwdriver to remove the six 11 mm screws on the bottom of the device.
  5. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 5、 1の画像 1
    • Remove the bottom cover from the device to reveal the motherboard.
  6. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 6、 1の画像 1
    • Use a Phillips screwdriver to remove the 9.5 mm screw located near the center of the motherboard.
  7. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 7、 1の画像 1
    • Lift the motherboard away from the device.
  8. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 8、 3の画像 1 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 8、 3の画像 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 8、 3の画像 3
    • Disconnect the four cables connecting the motherboard to the device.
  9. Insignia NS-CLIP02 Speaker replacement and troubleshooting, Speaker: 手順 9、 1の画像 1
    • Remove the three screws located along the center of the base.
  10. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 10、 2の画像 1 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 10、 2の画像 2
    • Remove the base from the display.
  11. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 11、 3の画像 1 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 11、 3の画像 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 11、 3の画像 3
    • Using a metal spudger, remove the plastic face plate from the display.
  12. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 12、 1の画像 1
    • With a phillips screwdriver, remove the six screws shown pictured to the left.
  13. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 13、 2の画像 1 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 13、 2の画像 2
    • Using the metal spudger, pry the speaker grilles from the display.
  14. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 14、 1の画像 1
    • Using the phillips screwdriver, remove the four screws pictured to the left.
  15. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 15、 1の画像 1
    • Separate the two pieces of the display as shown.
  16. Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 16、 3の画像 1 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 16、 3の画像 2 Insignia NS-CLIP02 Speaker replacement and troubleshooting: 手順 16、 3の画像 3
    • You can see that there are several points where connections to the speaker are soldered.
    • If all connections are soldered then replacement may be necessary.
終わりに
作成者
4人の作成者と共同で作成されました。
Aubrey
メンバー登録日: 02/24/15
214 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015人のメンバー
USFT-LEAHY-W15S9G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 5
今までの合計 169
