メインコンテンツにスキップ
Insignia NS-CLIP02 30-Pin Connector Replacement
必要な工具と部品
  1. Insignia NS-CLIP02 30-Pin Connector Replacement, 30-Pin Connector: 手順 1、 1の画像 1
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 2、 1の画像 1
    • Begin by using the Metal Spudger to peel back the adhesive sticker and locate the screw beneath the sticker.
  3. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 3、 1の画像 1
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 4、 1の画像 1
    • Using the Plastic Spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 5、 1の画像 1
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 6、 1の画像 1
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 7、 1の画像 1
    • Once you peel off the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 8、 1の画像 1
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 9、 1の画像 1
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 10、 1の画像 1
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 11、 1の画像 1
    • Begin with removing the plug to your left.
  12. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 12、 1の画像 1
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 13、 1の画像 1
    • Remove the plug in front of the LCD screen plug.
  14. Insignia NS-CLIP02 30-Pin Connector Replacement: 手順 14、 1の画像 1
    • Remove the LCD screen plug. Then, follow the previous instructions in reverse, replacing the old motherboard with the new one to fix the 30-Pin Connector.
終わりに
作成者
4人の作成者と共同で作成されました。
Erik
メンバー登録日: 02/19/15
405 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 9-3, Leahy Winter 2015 USF Tampa, Team 9-3, Leahy Winter 2015人のメンバー
USFT-LEAHY-W15S9G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 211
