必要な工具と部品
Turn the boombox around to see the back, and then flip it upside down.
Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
この手順で使用する道具:Flathead 3/32" or 2.5 mm Screwdriver$5.49
To remove the cassette unit, use a 2.5mm flathead on the 4 screws holding the unit together.
もう少しです!
終わりに
