はじめに
This guide shows you how to remove the antenna from the boombox.
必要な工具と部品
Unplug and remove the power cord. Turn the boombox upside down.
Grip the sides of the case and use your thumbs to pop open the battery cover.
Set the boombox upright. Remove the 4mm screw and the two 6mm washers with the Phillips PH1 screwdriver.
Remove the external antenna.
Turn the boombox upside down again. With the Phillips PH1 or the Flathead #3 screwdriver, remove the three 14mm black screws.
Remove the four 18mm chrome screws with the Phillips PH1 screwdriver.
Remove the 10mm chrome screw from the antenna base with the Phillips PH1 screwdriver. Remove the antenna base from the casing.
This red wire will now be loose and you can move it out of the antenna base slot.
