メインコンテンツにスキップ
Insignia NS-B2110 Transformer Replacement
必要な工具と部品
  1. Insignia NS-B2110 Transformer Replacement, Battery: 手順 1、 2の画像 1 Insignia NS-B2110 Transformer Replacement, Battery: 手順 1、 2の画像 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Transformer Replacement: 手順 2、 2の画像 1 Insignia NS-B2110 Transformer Replacement: 手順 2、 2の画像 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Insignia NS-B2110 Transformer Replacement, Bottom Panel: 手順 3、 1の画像 1
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Insignia NS-B2110 Transformer Replacement: 手順 4、 2の画像 1 Insignia NS-B2110 Transformer Replacement: 手順 4、 2の画像 2
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Insignia NS-B2110 Transformer Replacement: 手順 5、 3の画像 1 Insignia NS-B2110 Transformer Replacement: 手順 5、 3の画像 2 Insignia NS-B2110 Transformer Replacement: 手順 5、 3の画像 3
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
  6. Insignia NS-B2110 Transformer Replacement, Transformer: 手順 6、 2の画像 1 Insignia NS-B2110 Transformer Replacement, Transformer: 手順 6、 2の画像 2
    • Using a Phillips #2 screwdriver, remove two 4mm screws from the transformer box.
    • Remove the transformer and set it to the side.
  7. Insignia NS-B2110 Transformer Replacement: 手順 7、 1の画像 1
    • Remove the solder connecting the two yellow wires to the green quarter-circle board.
  8. Insignia NS-B2110 Transformer Replacement: 手順 8、 3の画像 1 Insignia NS-B2110 Transformer Replacement: 手順 8、 3の画像 2 Insignia NS-B2110 Transformer Replacement: 手順 8、 3の画像 3
    • There will be a strip of electrical tape securing the converter. Use scissors to carefully remove this tape.
    • Use a Phillips #2 screwdriver to remove two 4mm screws from the converter.
    • Remove the converter. There will be a plastic casing that slides off; set this aside.
  9. Insignia NS-B2110 Transformer Replacement: 手順 9、 1の画像 1
    • Remover the solder from the red and yellow wires on the converter.
終わりに
作成者
4人の作成者と共同で作成されました。
Jacob Phillips
メンバー登録日: 10/14/13
313 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-31, Amido Fall 2013 Cal Poly, Team 4-31, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S4G31
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 300
