メインコンテンツにスキップ
Insignia 24" LED Roku TV Screen Replacement
必要な工具と部品
  1. Insignia 24" LED Roku TV Screen Replacement, Remove the base: 手順 1、 3の画像 1 Insignia 24" LED Roku TV Screen Replacement, Remove the base: 手順 1、 3の画像 2 Insignia 24" LED Roku TV Screen Replacement, Remove the base: 手順 1、 3の画像 3
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia 24" LED Roku TV Screen Replacement: 手順 2、 3の画像 1 Insignia 24" LED Roku TV Screen Replacement: 手順 2、 3の画像 2 Insignia 24" LED Roku TV Screen Replacement: 手順 2、 3の画像 3
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the Phillips Head Screws from the the back of the TV.
  3. Insignia 24" LED Roku TV Screen Replacement, Pry the TV open: 手順 3、 1の画像 1
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia 24" LED Roku TV Screen Replacement, Disconnect wires: 手順 4、 3の画像 1 Insignia 24" LED Roku TV Screen Replacement, Disconnect wires: 手順 4、 3の画像 2 Insignia 24" LED Roku TV Screen Replacement, Disconnect wires: 手順 4、 3の画像 3
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia 24" LED Roku TV Screen Replacement: 手順 5、 1の画像 1
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
  6. Insignia 24" LED Roku TV Screen Replacement, Screen: 手順 6、 1の画像 1
    • Remove the tape that is holding the silver rectangular piece from the house.
  7. Insignia 24" LED Roku TV Screen Replacement: 手順 7、 2の画像 1 Insignia 24" LED Roku TV Screen Replacement: 手順 7、 2の画像 2
    • Using the Phillips 00 Screwdriver, remove the screws that are also holding the silver rectangular piece to the house.
  8. Insignia 24" LED Roku TV Screen Replacement: 手順 8、 3の画像 1 Insignia 24" LED Roku TV Screen Replacement: 手順 8、 3の画像 2 Insignia 24" LED Roku TV Screen Replacement: 手順 8、 3の画像 3
    • Remove the plastic casing from the glass screen.
    • Then carefully remove metal backing from glass screen and separate the layer of plastic from the glass screen.
  9. Insignia 24" LED Roku TV Screen Replacement: 手順 9、 2の画像 1 Insignia 24" LED Roku TV Screen Replacement: 手順 9、 2の画像 2
    • Separate plastic screen protector layers from both the backing and glass screen.
    • The second picture provides image of what the plastic screen protectors look like.
  10. Insignia 24" LED Roku TV Screen Replacement: 手順 10、 3の画像 1 Insignia 24" LED Roku TV Screen Replacement: 手順 10、 3の画像 2 Insignia 24" LED Roku TV Screen Replacement: 手順 10、 3の画像 3
    • Find the display board and unplug the white ribbon cord from the board.
    • Squeeze both sides of the plug to release the cord.
  11. Insignia 24" LED Roku TV Screen Replacement: 手順 11、 3の画像 1 Insignia 24" LED Roku TV Screen Replacement: 手順 11、 3の画像 2 Insignia 24" LED Roku TV Screen Replacement: 手順 11、 3の画像 3
    • Using same screwdriver, unscrew the screws that are on the green display board.
    • Separate the green display board from its metal backing.
  12. Insignia 24" LED Roku TV Screen Replacement: 手順 12、 1の画像 1
    • All cables connecting screen to frame are now detached.
    • Now pull apart and separate the screen.
終わりに
To reassemble your TV, follow these instructions in reverse order.
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Hannah Berenjfoorosh
メンバー登録日: 01/22/18
533 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S16-G2, Banghart Winter 2018 Cal Poly, Team S16-G2, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S16G2
4 メンバー
6のガイドは作成済み
コメント 1 件
How do I find a replacement screen? NS-32DF310NA19
Lakeisha - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 61
今までの合計 5,305
