メインコンテンツにスキップ
Insignia Flex Elite 7.85 Camera Replacement
必要な工具と部品
  1. Insignia Flex Elite 7.85 Camera  Replacement, Back Camera: 手順 1、 1の画像 1
    • Make sure the device is turned off before taking it apart to avoid any injuries.
    • Use a plastic opening tool to remove the metal backing of the tablet.
    • Insert the plastic opening tool between the screen and metal backing. Use a prying motion to lift the front case from the metal panel.
    • Move the tool around the perimeter of the device until the screen separates.
    • The volume and power button will become free from device when the screen and metal backing are separated. These small pieces are easy to lose, be careful. They’re easy to put back into place when reassembling the tablet.
  2. Insignia Flex Elite 7.85 Camera  Replacement: 手順 2、 2の画像 1 Insignia Flex Elite 7.85 Camera  Replacement: 手順 2、 2の画像 2
    • Once the the tablet is open, locate the camera.
    • There is a small black ribbon connector which connects the camera to the motherboard.
    • Use a plastic opening tool to pry slightly on the black ribbon connector.
    • Bend the black ribbon connector slightly so it will not be in the way.
  3. Insignia Flex Elite 7.85 Camera  Replacement: 手順 3、 1の画像 1
    • Using a plastic opening tool, pry the camera from the mount.
    • Pry around the perimeter of the camera until it comes free.
    • Be careful, make sure the plastic frame does not break.
  4. Insignia Flex Elite 7.85 Camera  Replacement: 手順 4、 2の画像 1 Insignia Flex Elite 7.85 Camera  Replacement: 手順 4、 2の画像 2
    • The camera should be out of its housing by now. Reinstall new camera.
終わりに
作成者
2人の作成者と共同で作成されました。
Antonio Olivieri
メンバー登録日: 03/21/17
401 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S9-G2, Martin Spring 2017 UMass Dartmouth, Team S9-G2, Martin Spring 2017人のメンバー
UMASSD-MARTIN-S17S9G2
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 112
