メインコンテンツにスキップ
Insignia Flex Elite 7.85 Battery Replacement
必要な工具と部品
  1. Insignia Flex Elite 7.85 Battery  Replacement, Battery: 手順 1、 2の画像 1 Insignia Flex Elite 7.85 Battery  Replacement, Battery: 手順 1、 2の画像 2
    • Make sure the device is turned off before taking it apart to avoid any injuries
    • Use a plastic opening tool to remove the metal backing of the tablet.
    • Insert the plastic opening tool between the screen and metal backing. Use a prying motion to lift the front case from the metal panel.
    • Move the tool around the perimeter of the device until the screen separate.
    • The volume and power button will become free from device when the screen and metal backing are separated. These small pieces are easy to lose, be careful. They’re easy to put back into place when reassembling the tablet.
  2. Insignia Flex Elite 7.85 Battery  Replacement: 手順 2、 3の画像 1 Insignia Flex Elite 7.85 Battery  Replacement: 手順 2、 3の画像 2 Insignia Flex Elite 7.85 Battery  Replacement: 手順 2、 3の画像 3
    • Use a plastic opening tool to free the orange connector ribbon by placing the tool on the connector. Then peal the connector ribbon and bend it backwards so it is not in the way.
  3. Insignia Flex Elite 7.85 Battery  Replacement: 手順 3、 2の画像 1 Insignia Flex Elite 7.85 Battery  Replacement: 手順 3、 2の画像 2
    • Peel back the three pieces of tape circled in the picture.
  4. Insignia Flex Elite 7.85 Battery  Replacement: 手順 4、 1の画像 1
    • Free the battery from the motherboard by prying slightly with the opening tool
  5. Insignia Flex Elite 7.85 Battery  Replacement: 手順 5、 1の画像 1
    • Use the plastic opening tool to remove the battery from the screen.
    • Use a plastic opening tool to gently but firmly pry the battery up along the edges until it is free.
    • Do not bend or puncture the battery or the battery will begin to leak.
    • This step takes the longest. Be careful and do not rush through it. The glue on the back of the battery is difficult to free up.
  6. Insignia Flex Elite 7.85 Battery  Replacement: 手順 6、 1の画像 1
    • The battery should be removed from the tablet. Now replace the battery.
終わりに
作成者
1人の作成者と共同作成されました。
Antonio Olivieri
メンバー登録日: 03/21/17
401 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S9-G2, Martin Spring 2017 UMass Dartmouth, Team S9-G2, Martin Spring 2017人のメンバー
UMASSD-MARTIN-S17S9G2
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 456
