メインコンテンツにスキップ
Insignia Flex 8 NS-P16AT08 Speakers Replacement
必要な工具と部品
  1. Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: 手順 1、 3の画像 1 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: 手順 1、 3の画像 2 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Back Casing: 手順 1、 3の画像 3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Speakers Replacement: 手順 2、 1の画像 1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Speakers Replacement, Speakers: 手順 3、 2の画像 1 Insignia Flex 8 NS-P16AT08 Speakers Replacement, Speakers: 手順 3、 2の画像 2
    • There are two connections that attach the speakers to the motherboard.
    • Unplug the cables from the motherboard by gently pulling them away.
    • Speaker cables will be free to be removed.
  4. Insignia Flex 8 NS-P16AT08 Speakers Replacement: 手順 4、 2の画像 1 Insignia Flex 8 NS-P16AT08 Speakers Replacement: 手順 4、 2の画像 2
    • Remove the tape that is holding the speaker cables down.
    • Remove the speaker cables from underneath the black connector ribbons.
    • The cables are hooked underneath black connector ribbons; carefully unhook them.
  5. Insignia Flex 8 NS-P16AT08 Speakers Replacement: 手順 5、 1の画像 1
    • Gently pry both speakers away from adhesive with metal spudger tool.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • The speakers can now be completely removed from the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Jose Diaz
メンバー登録日: 04/03/16
20 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 2-1, Andersen Spring 2016 Eastern Washington University, Team 2-1, Andersen Spring 2016人のメンバー
EWU-ANDERSEN-S16S2G1
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 208
