メインコンテンツにスキップ
Insignia Flex 8 NS-P16AT08 Cameras Replacement
必要な工具と部品
  1. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: 手順 1、 3の画像 1 Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: 手順 1、 3の画像 2 Insignia Flex 8 NS-P16AT08 Cameras Replacement, Back Casing: 手順 1、 3の画像 3
    • Make sure device is powered off.
    • Wedge the plastic opening tool anywhere in the seam between the back casing and screen.
    • Slide the plastic opening tool along the sides and corners of the seam of the device while it separates from the screen.
    • You will hear the popping sound of the plastic connections separating from the device.
  2. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 手順 2、 1の画像 1
    • Lift the back casing away from the screen.
    • Set casing aside.
  3. Insignia Flex 8 NS-P16AT08 Cameras Replacement, Cameras: 手順 3、 1の画像 1
    • Gently peel all of the tape that is covering the cable connections going to and from the cameras. Set the tape aside for later reassembly.
  4. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 手順 4、 2の画像 1 Insignia Flex 8 NS-P16AT08 Cameras Replacement: 手順 4、 2の画像 2
    • Locate camera ribbon connector.
    • Using finger flip up black flap of camera ribbon connector.
  5. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 手順 5、 1の画像 1
    • Gently pull camera connector ribbon by hand until it separates from connector.
  6. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 手順 6、 1の画像 1
    • Using metal spudger tool, gently pry right speaker away from adhesive.
    • Always use a nylon spudger or plastic opening tool before a metal spudger. Metal spudgers are great for serious prying power but can damage your device if used incorrectly.
    • Move right speaker to left side of device so you can freely access the camera ribbon.
  7. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 手順 7、 1の画像 1
    • Using metal spudger tool, gently pry the rear-facing camera from the adhesive.
  8. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 手順 8、 1の画像 1
    • Lift up connector ribbon that is attached to the cameras.
    • Slide cameras and connector ribbon out from underneath the speaker cords and battery.
  9. Insignia Flex 8 NS-P16AT08 Cameras Replacement: 手順 9、 1の画像 1
    • Remove connector ribbon and cameras from device casing.
終わりに
作成者
3人の作成者と共同で作成されました。
Emily Guidinger
メンバー登録日: 04/01/16
527 ポイント
4のガイドは作成済み
チーム
Eastern Washington University, Team 2-1, Andersen Spring 2016 Eastern Washington University, Team 2-1, Andersen Spring 2016人のメンバー
EWU-ANDERSEN-S16S2G1
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 222
