メインコンテンツにスキップ
Insignia Flex 8 NS-P08A7100 Screen Replacement
必要な工具と部品
  1. Insignia Flex 8 NS-P08A7100 Screen Replacement, Screen: 手順 1、 2の画像 1 Insignia Flex 8 NS-P08A7100 Screen Replacement, Screen: 手順 1、 2の画像 2
    • Begin by using the opening tool to pry open the back cover. Continue around the edge until the back cover pops off.
  2. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 2、 2の画像 1 Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 2、 2の画像 2
    • Use the opening tool to flip the LCD flex circuit plug upwards. The flex circuit should now be loose. Remove flex circuit by pulling outwards.
  3. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 3、 2の画像 1 Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 3、 2の画像 2
    • Use the opening tool to remove the battery cable from the circuit board.
  4. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 4、 1の画像 1
    • Remove the adhesive tape from the bottom of the battery.
  5. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 5、 1の画像 1
    • Remove plastic adhesive tape from the side of the battery.
  6. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 6、 2の画像 1 Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 6、 2の画像 2
    • Pry the battery from the back of the LCD screen using the opening tool. Due to the strong adhesive between the battery and screen, this may take some time.
  7. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 7、 1の画像 1
    • Begin removing the screws on the circuit board using the phillips-head bit driver. Start with the top left corner.
  8. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 8、 1の画像 1
    • Remove the next screw to the right using the phillips-head bit driver.
  9. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 9、 1の画像 1
    • Remove the next screw to the right using the phillips-head bit driver. This one is slightly hidden under the flex circuit of the camera.
  10. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 10、 1の画像 1
    • Remove the next screw in the right top right using the phillips-head bit driver.
  11. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 11、 1の画像 1
    • Remove the next screw in the bottomeright corner using the phillips-head bit driver.
  12. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 12、 1の画像 1
    • Remove the next screw in the bottom left corner using the phillips-head bit driver.
  13. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 13、 1の画像 1
    • Remove the flex circuit on the left side of the circuit board using the opening tool.
  14. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 14、 1の画像 1
    • Remove the speaker cable from the circuit board using the opening tool.
  15. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 15、 1の画像 1
    • Remove the camera cable from the circuit board using the opening tool.
  16. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 16、 1の画像 1
    • Flip the camera flex circuit clip upwards using the opening tool. Detach the camera flex circuit from the circuit board
  17. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 17、 1の画像 1
    • Remove the adhesive tape holding the circuit board to the LCD screen. The circuit should now be free.
  18. Insignia Flex 8 NS-P08A7100 Screen Replacement: 手順 18、 1の画像 1
    • Pull the circuit board forward for clearance and begin removing the screen with the opening tool.
終わりに
作成者
3人の作成者と共同で作成されました。
Marco Soto
メンバー登録日: 07/08/19
347 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S1-G1, Renguette Summer 2019 IUPUI, Team S1-G1, Renguette Summer 2019人のメンバー
IUPUI-RENGUETTE-SU19S1G1
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 7
今までの合計 351
