必要な工具と部品
Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
Use a plastic opening tool to flip up the black strip that is holding the orange camera ribbon near the module on the circuit board labeled "front camera" in white print.
Repeat this action on the orange camera ribbon near the module on the circuit board labeled "back camera" in white print.
Use a plastic opening tool to flip up the black strip on the white module which is holding the connection between the other display ribbon and the circuit board.
Once the black strip has been flipped up, the connection between the module and the ribbon has been unlocked. Use the spudger to pull the ribbon towards you in order to completely disconnect it from the circuit board.
Turn the circuit board upside down so that the speakers are closest to you.
