メインコンテンツにスキップ
Insignia Flex 8 NS-15AT08 Cameras Replacement
必要な工具と部品
  1. Insignia Flex 8 NS-15AT08 Cameras Replacement, Back Casing: 手順 1、 2の画像 1 Insignia Flex 8 NS-15AT08 Cameras Replacement, Back Casing: 手順 1、 2の画像 2
    • Insert a plastic opening tool into the seam between the back casing and the screen to separate the back casing from the tablet.
    • You may need to use a metal opening tool for extra prying power, but beware that it can scratch your device or damage the internal components if the tool is inserted too deep.
    • You will hear the tabs pop as you separate the back casing around the tablet.
  2. Insignia Flex 8 NS-15AT08 Cameras Replacement: 手順 2、 2の画像 1 Insignia Flex 8 NS-15AT08 Cameras Replacement: 手順 2、 2の画像 2
    • Lift the back casing away from the rest of the device which should include the exposed circuit board and screen.
    • Set the casing aside.
  3. Insignia Flex 8 NS-15AT08 Cameras Replacement, Cameras: 手順 3、 1の画像 1
    • Use a plastic opening tool to flip up the black strip that is holding the orange camera ribbon near the module on the circuit board labeled "front camera" in white print.
    • Repeat this action on the orange camera ribbon near the module on the circuit board labeled "back camera" in white print.
  4. Insignia Flex 8 NS-15AT08 Cameras Replacement: 手順 4、 2の画像 1 Insignia Flex 8 NS-15AT08 Cameras Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to gently pull on both orange camera ribbons in the opposite direction in which they are connected until they disconnect from the modules on the circuit board.
  5. Insignia Flex 8 NS-15AT08 Cameras Replacement: 手順 5、 2の画像 1 Insignia Flex 8 NS-15AT08 Cameras Replacement: 手順 5、 2の画像 2
    • Peel off the grey tape covering the ribbons, in order to separate the cameras and their respective ribbons from the rest of the device.
    • Do not use excessive force while removing the tape to prevent tears in the ribbons.
  6. Insignia Flex 8 NS-15AT08 Cameras Replacement: 手順 6、 1の画像 1
    • Use a a plastic opening tool to pry out the back camera at the top of the circuit board.
終わりに
作成者
3人の作成者と共同で作成されました。
Krystal Rhodes
メンバー登録日: 09/22/15
488 ポイント
3のガイドは作成済み
チーム
Baylor, Team 6-7, Williams Fall 2015 Baylor, Team 6-7, Williams Fall 2015人のメンバー
BU-WILLIAMS-F15S6G7
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 199
