はじめに
Use this guide to replace the speaker of the Insignia Flex 10.1 tablet.
必要な工具と部品
The rear panel is secured to the front case by 26 clips attached to the rear panel. These clips lock onto small tabs machined into the front case.
To free the tabs, they must be pushed toward the center of the device. When using the plastic opening tool to free the rear panel, be sure to work the tool at the location of these clips.
To help in visualization, the __ clips boxed in red are located closest to the __.
Remove back cover by inserting a plastic opening tool along the edge of the device to release the clips.
Opening the Flex 10.1 can be challenging. Don't get discouraged if it takes multiple attempts before the Flex 10.1 is opened.
Insert the plastic opening tool into the seam between the front case and the rear panel of the Flex 10.1.
Gently enlarge the existing gap by pressing and wiggling the plastic opening tool into the gap near each of the clips attached to the rear case, pushing the clips toward the center of the device until the clips have been freed.
Repeat the same procedure to free all clips around the Flex 10.1.
