メインコンテンツにスキップ
Insignia Flex 10.1 NS-P10W8100 Keyboard Connector Replacement
必要な工具と部品
  1. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement, Keyboard Connector: 手順 1、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement, Keyboard Connector: 手順 1、 2の画像 2
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: 手順 2、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: 手順 2、 2の画像 2
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to each side to help pry the back cover evenly.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: 手順 3、 1の画像 1
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off work your fingers around the corners and slowly pry the cover off.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: 手順 4、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: 手順 4、 2の画像 2
    • Use your fingers to remove the tape holding down the zero insertion force (ZIF) connector ribbon attached to the keyboard.
    • Use your fingernails to flip the small locking flap. Then, you can safely pull the cable out.
  5. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: 手順 5、 1の画像 1
    • Pull back the yellow tape holding down the keyboard connector.
  6. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: 手順 6、 1の画像 1
    • Remove the two 4 mm screws using a Phillips #2 screwdriver.
  7. Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: 手順 7、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Keyboard Connector  Replacement: 手順 7、 2の画像 2
    • Remove the connector by lifting it upward.
終わりに
作成者
3人の作成者と共同で作成されました。
Edgar Rodriguez
メンバー登録日: 02/12/19
971 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G2, Virtue Spring 2019 Western Carolina University, Team S1-G2, Virtue Spring 2019人のメンバー
WCU-VIRTUE-S19S1G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 9
今までの合計 934
