メインコンテンツにスキップ
Insignia Flex 10.1 NS-P10W8100 Camera Replacement
必要な工具と部品
  1. Insignia Flex 10.1 NS-P10W8100 Camera Replacement, Camera: 手順 1、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Camera Replacement, Camera: 手順 1、 2の画像 2
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 手順 2、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 手順 2、 2の画像 2
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to each side to help pry the back cover evenly.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 手順 3、 1の画像 1
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off work your fingers around the corners and slowly pry the cover off using your fingers.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 手順 4、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 手順 4、 2の画像 2
    • Carefully remove the yellow tape holding down the camera ribbon connector by pulling it upwards.
    • Remove the black tape holding down the camera ribbon connector which is attached to the motherboard.
  5. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 手順 5、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 手順 5、 2の画像 2
    • Disconnect the zero insertion force (ZIF) connector by using your fingernail to flip the small locking flap.
    • Disconnect the cable by gently pulling it outward.
  6. Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 手順 6、 3の画像 1 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 手順 6、 3の画像 2 Insignia Flex 10.1 NS-P10W8100 Camera Replacement: 手順 6、 3の画像 3
    • Remove the camera by pulling it upward.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Edgar Rodriguez
メンバー登録日: 02/12/19
971 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G2, Virtue Spring 2019 Western Carolina University, Team S1-G2, Virtue Spring 2019人のメンバー
WCU-VIRTUE-S19S1G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 191
