メインコンテンツにスキップ
Insignia Flex 10.1 NS-P10W8100 Battery Replacement
必要な工具と部品
  1. Insignia Flex 10.1 NS-P10W8100 Battery Replacement, Battery: 手順 1、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Battery Replacement, Battery: 手順 1、 2の画像 2
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: 手順 2、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: 手順 2、 2の画像 2
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to the edge closest to the screen.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: 手順 3、 1の画像 1
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off, work your fingers around the corners and slowly pry the cover off using your fingers.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: 手順 4、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: 手順 4、 2の画像 2
    • Unplug the power supply by disconnecting the red and blue wires found on the motherboard.
  5. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: 手順 5、 1の画像 1
    • Remove the black tape from the Zero Insertion Force (ZIF) ribbon connector.
  6. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: 手順 6、 2の画像 1 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: 手順 6、 2の画像 2
    • Lift up on the black locking flap, being careful not to damage the surrounding hardware parts.
    • Remove the ZIF ribbon wire by pulling horizontally towards the battery.
  7. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: 手順 7、 1の画像 1
    • Remove the black tape from the small ribbon wire connector.
    • Pull the ribbon connector out of the plug the same way that was mentioned in step 4.
  8. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: 手順 8、 1の画像 1
    • Use the spudger to separate the battery from the base.
    • The battery can be difficult to remove as it is held in with double sided tape.
    • Be sure not to pry on the battery too hard because damage to the screen and/or the battery can occur.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Edgar Rodriguez
メンバー登録日: 02/12/19
971 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team S1-G2, Virtue Spring 2019 Western Carolina University, Team S1-G2, Virtue Spring 2019人のメンバー
WCU-VIRTUE-S19S1G2
4 メンバー
5のガイドは作成済み
2 件のコメント
Very concise and helpful. Thank you
Frank Schaffer - 返信
where can i buy the replacement battery?
José Porras - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 18
今までの合計 1,051
