メインコンテンツにスキップ
Insignia 6-Quart Pressure Cooker Circuit Board Replacement
必要な工具と部品
  1. Insignia 6-Quart Pressure Cooker Circuit Board Replacement, Circuit Board and Power Cord: 手順 1、 1の画像 1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw.
  2. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 2、 1の画像 1
    • Twist the light grey plastic until the holes align with the blockers.
    • Remove the light grey plastic cover.
  3. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 3、 1の画像 1
    • Remove the power cord from the slot it is inserted in.
  4. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 4、 1の画像 1
    • Use a Phillips head #2 screwdriver to remove the 22mm screw connected to the black wire.
  5. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 5、 1の画像 1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the red wire.
  6. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 6、 1の画像 1
    • Use a Phillips head #2 screwdriver to remove the 8mm screw and it's washer from the blue wire.
  7. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 7、 1の画像 1
    • Pinch the small white component connected to the circuit board.
    • Once pinched, wiggle this component until it is disconnected.
  8. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 8、 1の画像 1
    • Pinch the red component connected to the circuit board.
  9. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 9、 1の画像 1
    • Wiggle the wide white component until it is removed from the circuit board.
  10. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 10、 1の画像 1
    • Use a J1 head screwdriver to remove the 8mm screws from both sides of the circuit board.
  11. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 11、 1の画像 1
    • Use a Phillips head #2 screwdriver to remove both 15mm screws from either side of the circuit board, indicated in the picture.
  12. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 12、 1の画像 1
    • Position the pressure cooker so that the circuit board is farther from you then the black, red, and blue wire connections.
    • To the right of the board, use a Phillips head #2 screwdriver to remove the 6mm screw.
  13. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 13、 1の画像 1
    • Use a Phillips head #2 screwdriver to remove the 6mm screw behind and to the right of the circuit board tray.
  14. Insignia 6-Quart Pressure Cooker Circuit Board Replacement: 手順 14、 1の画像 1
    • Remove and replace the circuit board.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Savannah Webb
メンバー登録日: 01/18/18
657 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S12-G3, Banghart Winter 2018 Cal Poly, Team S12-G3, Banghart Winter 2018人のメンバー
CPSU-BANGHART-W18S12G3
4 メンバー
5のガイドは作成済み
8 件のコメント
Where do you purchase the circuit board
Douglas Koons - 返信
Hi, thanks for the guide. Where could I purchase the circuit board?
Anthea - 返信
Please, Where can I buy the electrical circuit?
Mohammed - 返信
why is my circuit board not fixed to the top like in the diagram
david stanley - 返信
where can I purchase the circuit board
de27@bellsouth.net - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 28
今までの合計 3,168
