メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
You'll probably never need to diagnose an instrument light problem with your car, but that doesn't mean you can't have fun performing this test. And knowing that the gauges and lights are working is reassuring.
If you want to show this to friends, be warned that HID headlights service life can be reduced by turning them on and off needlessly. The bulbs aren't cheap. I recommend pulling the fuses for them before doing this repeated.
This procedure is specific to HONDAs and ACURAs.
ツール
ツールは指定されていません。
パーツ
  1. This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure.  As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
    • This procedure involves turning on and off the headlights repeatedly, which which can reduce the HID headlights' mean lifetime before failure. As a precursor, consider removing the 15A left & right low headlight fuses from the under-hood fuse box, positions 1 and 6. (Refer to your Owners Manual for instructions, or an iFixit guide.)
    • Be sure to reinstall the low beam headlight fuses before driving the vehicle.
  2. Insert the ignition key into the ignition lock. Leave it in the 0 or I position. Push and hold the Sel/Reset  knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display  Info button. Push and hold the Sel/Reset  knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display  Info button.
    • Insert the ignition key into the ignition lock. Leave it in the 0 or I position.
    • Push and hold the Sel/Reset knob (on the instrument panel by the fuel gauge), or the Sel/reset button on the right hand of the steering wheel below the Multi-Information Display Info button.
  3. Turn the headlights ON.
    • Turn the headlights ON.
  4. Turn the ignition switch to ON (position II). Some of the instrument lights will come on. If you aren't wearing your seatbelt, the seatbelt warning chime will sound.
    • Turn the ignition switch to ON (position II).
    • Some of the instrument lights will come on. If you aren't wearing your seatbelt, the seatbelt warning chime will sound.
  5. Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again. Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again. Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
    • Within five seconds, and still holding in the Sel/Reset button, turn the headlights OFF, then ON, then OFF again.
  6. Within 5 seconds, release the Sel/reset button. Push and release the Sel/reset button button 3 times repeatedly. The instrument cluster begins its self-test.
    • Within 5 seconds, release the Sel/reset button.
    • Push and release the Sel/reset button button 3 times repeatedly.
    • The instrument cluster begins its self-test.
    • Each successive press of the Sel/reset button initiates a new cycling of all the gauges.
    • To end, turn the ignition switch to OFF, or vehicle speed exceeds 1.5 mph.
    • If you removed the 15A headlight fuses from the under-hood fuse box in step 1, reinstall them before driving.
ゴール
10 の人々がこのガイドを完成させました。
David Spalding
メンバー登録日: 2015年11月12日
5,896 ポイント
9のガイドは作成済み
10 件のコメント
This looks like the fix I may be looking for! What make or model vehicle is this? My Chrysler Town & Country used to occasionally get the gauge needles pinned to infinite and there was a similar procedure to run the self test and reset the needles. My Mom’s old GM Delta 88 has been having a similar problem and I am wondering if this procedure will work on her car.
George Hickey - 返信
Make, model, and series is clearly identified on this page.
David Spalding -
We have seen a lot of the same issues plaguing 2003-2013 GM brand gauge clusters. If you ever have questions or need help with a gm gauge repair, don’t hesitate to reach out!
-Paul, Owner
Custom Auto - 返信
I replaced the stepper motors in a 2003 Tahoe and added blue lights as well on a used board. Plugged it in and everything works but all the prompts are in French and it looks like it added the mileage from the truck and replacement board. Is there a way to flash replacement board over to the Tahoe? Thanks
trish Hampton -
My 2004 colorado 4 door dash lights went out driving one night about 2 weeks ago, it froze on whatever it was on. Shows I'm going 45 miles an hour, also gauges for fuel and temperature are stuck to. Signals lights don't light up either. They work, lights work, brake lights and backup lights work too. Fuses checked out ok, I'm lost, cant figure it out. Please Help !!!
Thresea Rhodes -
コメントを追加
統計データを表示:
過去 24時間: 93
過去 7 日: 655
過去 30 日: 3,432
今までの合計 205,626
