パーツ
パーツは必要ありません。
  1. Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
    • Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
    • To ensure you don't lose any tiny parts during the replacement process, place parts on the white magnetic sheet.
    • Once the screws have been removed, proceed to take off back cover.
  2. Now, proceed to lift the battery out and remove it.
    • Now, proceed to lift the battery out and remove it.
    • Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
    • Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
    • Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary.
    • Pull the motherboard out and down away from the top of the phone.
まとめ
Lauren
メンバー登録日: 2014年02月13日
43 ポイント
2のガイドは作成済み
チーム
Ohio State, Team 1-4, Buehl Spring 2014 Ohio State, Team 1-4, Buehl Spring 2014人のメンバー
OSU-BUEHL-S14S1G4
3 メンバー
3のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 421
