メインコンテンツにスキップ
Infinity v2 10.1 Speakers Replacement
必要な工具と部品
  1. Infinity v2 10.1 Speakers Replacement, Back Case: 手順 1、 3の画像 1 Infinity v2 10.1 Speakers Replacement, Back Case: 手順 1、 3の画像 2 Infinity v2 10.1 Speakers Replacement, Back Case: 手順 1、 3の画像 3
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Speakers Replacement: 手順 2、 2の画像 1 Infinity v2 10.1 Speakers Replacement: 手順 2、 2の画像 2
    • Remove the speakers from the case by gently lifting them up and out of their slots.
  3. Infinity v2 10.1 Speakers Replacement, Speakers: 手順 3、 1の画像 1
    • Turn on your soldering iron and allow it to heat up. Once it is hot, press the tip of the iron to the both of the solder points that attach the wires to the motherboard until the solder is melted.
    • Once the solder is melted, use tweezers to remove the wires from the motherboard.
    • The solder and iron will be extremely hot. You can use tweezers to grab the wire to avoid burning your fingers from accidental contact with the iron.
終わりに
作成者
5人の作成者と共同で作成されました。
Nate Rice
メンバー登録日: 10/31/19
321 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 UMass Dartmouth, Team S2-G4, Barthe Fall 2019人のメンバー
UMASSD-BARTHE-F19S2G4
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 108
