はじめに
Replace a faulty speaker.
必要な工具と部品
Using the plastic opening tool, remove screen protector from front of monitor.
Disconnect speaker from monitor for ease of access by unplugging wire.
Thank you so much for this - and thank you to the commenter who walked through the additional screen replacement steps! I’ve never done anything like this and I managed to replace the screen myself.
Use a heat gun to soften and easily remove epoxy that surrounds the speaker. Gently scrape it free little by little with metal spudger.
Be more specific about how to remove the speaker. Explain how to soften the adhesive, etc. Make sure you point out which tools to use when removing the speaker. How do you grasp it?
Lift the speaker from casing using metal spudger.
Place new 8W speaker in the casing and connect wire.
3 の人々がこのガイドを完成させました。
5 件のコメント
Where to purchase the replacement speaker?
Where can we purchase the replacement 8w speaker part
lea placek - 返信
8W Speaker is incorrect.
The speaker needed is 8 Ohm 0.5 Watt.
Ryan Ernde - 返信
Thanks for this. Found something on Ali Express, just need to figure out the right size
itryit -
This is good to show how you get it open. Unless you have a speaker that has the plastic piece that connects to the mother board, then it’s useless. The speaker I ordered just had two free standing wires.
Mark Ruddy - 返信
There's a layer of adhesive between the screen protector and the white plastic behind it.
Jared Astillero - 返信
The cover is glued on. So you’ll nee d quite a bit of force to bend it up. But then it’ll come lose glue point by glue point. At first I was afraid that I’ll break it.
Marco Smolla - 返信
