メインコンテンツにスキップ
Infant Optics DXR-8 Back Cover Prerequisite
必要な工具と部品
  1. Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: 手順 1、 3の画像 1 Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: 手順 1、 3の画像 2 Infant Optics DXR-8 Back Cover Prerequisite, Internal Monitor Components: 手順 1、 3の画像 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Back Cover Prerequisite: 手順 2、 3の画像 1 Infant Optics DXR-8 Back Cover Prerequisite: 手順 2、 3の画像 2 Infant Optics DXR-8 Back Cover Prerequisite: 手順 2、 3の画像 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Back Cover Prerequisite: 手順 3、 3の画像 1 Infant Optics DXR-8 Back Cover Prerequisite: 手順 3、 3の画像 2 Infant Optics DXR-8 Back Cover Prerequisite: 手順 3、 3の画像 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
終わりに
20 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Peyton Ulrich
メンバー登録日: 01/24/17
515 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 13-4, Banghart Winter 2017 Cal Poly, Team 13-4, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S13G4
4 メンバー
4のガイドは作成済み
27 件のコメント
Great walkthrough. One suggestion i have is to make sure to remove the battery before doing any of the disassembly. Great guide!
Derrick Brown - 返信
Any idea where I could buy a replacement screen though? I just dropped mine and the screen is broken. The front plastic is still undamaged.
Jon Woolery - 返信
I bought a Sharp LQ035NC111 LCD Display eBay for $8.46 and it did the trick
Nathaniel Wolf -
Do you know where I could buy a replacement screen for this device? I just dropped mine and the only damage that I can see is a crack in the LCD that is making the image almost entirely unviewable.
Jon Woolery - 返信
I replaced mine with a “3.5" Inch QVGA 240x320 TFT Color LCD Display Module LQ035NC111 54pin” I found on ebay for $8.81, works great.
Just Being Helpful -
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 31
過去 30 日: 156
今までの合計 29,452
