Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
Remove the hex head bolt from the top of the access door on the pump head.
The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
Make sure there is at least 6 inches of space between the joint and the rod clamp to allow yourself enough room to work. If necessary, continue pulling the rod out of the well before tightening the rod clamp to ensure sufficient spacing.
