この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will lead you through removing the traveling valve from the pump cylinder. It can then be replaced as a unit, or disassembled further to replace an individual internal component.
必要な工具と部品
Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
Pull the assembly of riser main pipe and cylinder out of the well and set the assembly on a block of wood to keep the cylinder off the ground.
Insert a wrench into the slots located at the bottom of the traveling valve.
Using another wrench for leverage, unscrew the valve off the pump rod.
