メインコンテンツにスキップ
India Mark II Riser Main (Tripod) Replacement
必要な工具と部品
  1. India Mark II Riser Main (Tripod) Replacement, Access Door: 手順 1、 2の画像 1 India Mark II Riser Main (Tripod) Replacement, Access Door: 手順 1、 2の画像 2
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. India Mark II Riser Main (Tripod) Replacement: 手順 2、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 2、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 2、 3の画像 3
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. India Mark II Riser Main (Tripod) Replacement: 手順 3、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 3、 2の画像 2
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
  4. India Mark II Riser Main (Tripod) Replacement, Chain: 手順 4、 3の画像 1 India Mark II Riser Main (Tripod) Replacement, Chain: 手順 4、 3の画像 2 India Mark II Riser Main (Tripod) Replacement, Chain: 手順 4、 3の画像 3
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
  5. India Mark II Riser Main (Tripod) Replacement: 手順 5、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 5、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 5、 3の画像 3
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
  6. India Mark II Riser Main (Tripod) Replacement: 手順 6、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 6、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 6、 3の画像 3
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
  7. India Mark II Riser Main (Tripod) Replacement: 手順 7、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 7、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 7、 3の画像 3
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
  8. India Mark II Riser Main (Tripod) Replacement: 手順 8、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 8、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 8、 3の画像 3
    • Remove the nut from the chain bolt.
  9. India Mark II Riser Main (Tripod) Replacement: 手順 9、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 9、 2の画像 2
    • Remove the washer from the chain bolt.
  10. India Mark II Riser Main (Tripod) Replacement: 手順 10、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 10、 2の画像 2
    • Remove the chain bolt.
  11. India Mark II Riser Main (Tripod) Replacement: 手順 11、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 11、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 11、 3の画像 3
    • Pull the top of the chain straight off of the pump handle.
  12. India Mark II Riser Main (Tripod) Replacement, Head: 手順 12、 3の画像 1 India Mark II Riser Main (Tripod) Replacement, Head: 手順 12、 3の画像 2 India Mark II Riser Main (Tripod) Replacement, Head: 手順 12、 3の画像 3
    • Remove the two bolts from the handle side of the pump head.
    • Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
  13. India Mark II Riser Main (Tripod) Replacement: 手順 13、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 13、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 13、 3の画像 3
    • Remove the two bolts and nuts from the handle side.
  14. India Mark II Riser Main (Tripod) Replacement: 手順 14、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 14、 2の画像 2
    • After removing the two handle side bolts, have your partner support the weight of the handle.
    • Remove the two remaining bolts in the same fashion.
  15. India Mark II Riser Main (Tripod) Replacement: 手順 15、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 15、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 15、 3の画像 3
    • Lift and remove the pump head from the pump.
    • Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
  16. India Mark II Riser Main (Tripod) Replacement, Chain: 手順 16、 2の画像 1 India Mark II Riser Main (Tripod) Replacement, Chain: 手順 16、 2の画像 2
    • Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
  17. India Mark II Riser Main (Tripod) Replacement: 手順 17、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 17、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 17、 3の画像 3
    • Lift the head flange up about one foot above the tank.
  18. India Mark II Riser Main (Tripod) Replacement: 手順 18、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 18、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 18、 3の画像 3
    • Slide the rod clamp around the pump rod, and support it on the tank base.
    • Make sure the pegs in the base of the rod clamp fit into the appropriate holes in the top of the tank.
  19. India Mark II Riser Main (Tripod) Replacement: 手順 19、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 19、 2の画像 2
    • Tighten the rod clamp against the pump rod.
    • Be sure the pump rod is centered within the jaws of the clamp and held securely.
  20. India Mark II Riser Main (Tripod) Replacement: 手順 20、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 20、 2の画像 2
    • Lower the head flange.
  21. India Mark II Riser Main (Tripod) Replacement: 手順 21、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 21、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 21、 3の画像 3
    • Unscrew the chain from the top of the pump rod.
    • Remove the chain.
    • Check the chain for signs of wear or damage.
    • Set the chain in a sanitary place, such as the access door that was previously removed.
  22. India Mark II Riser Main (Tripod) Replacement, Head Flange: 手順 22、 3の画像 1 India Mark II Riser Main (Tripod) Replacement, Head Flange: 手順 22、 3の画像 2 India Mark II Riser Main (Tripod) Replacement, Head Flange: 手順 22、 3の画像 3
    • Remove the chain support from around the pump rod.
  23. India Mark II Riser Main (Tripod) Replacement: 手順 23、 1の画像 1
    • Remove the jam nut from the top of the pump rod.
  24. India Mark II Riser Main (Tripod) Replacement: 手順 24、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 24、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 24、 3の画像 3
    • Remove the head flange.
  25. India Mark II Riser Main (Tripod) Replacement: 手順 25、 1の画像 1
    • Screw the jam nut back onto the top of the pump rod.
  26. India Mark II Riser Main (Tripod) Replacement, Tank: 手順 26、 3の画像 1 India Mark II Riser Main (Tripod) Replacement, Tank: 手順 26、 3の画像 2 India Mark II Riser Main (Tripod) Replacement, Tank: 手順 26、 3の画像 3
    • Screw a T-handle onto the top of the pump rod. Tighten the T-handle up against the jam nut.
  27. India Mark II Riser Main (Tripod) Replacement: 手順 27、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 27、 2の画像 2
    • Loosen the rod vise.
  28. India Mark II Riser Main (Tripod) Replacement: 手順 28、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 28、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 28、 3の画像 3
    • Remove the rod vise from the tank.
  29. India Mark II Riser Main (Tripod) Replacement: 手順 29、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 29、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 29、 3の画像 3
    • Remove the four bolts connecting the tank to the top flange.
    • Use one wrench on the bolt and a second wrench on the nut beneath. Hold the bolt still and loosen the nut.
  30. India Mark II Riser Main (Tripod) Replacement: 手順 30、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 30、 2の画像 2
    • Twist the tank 45 degrees in order to get a better grasp on it.
  31. India Mark II Riser Main (Tripod) Replacement: 手順 31、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 31、 2の画像 2
    • Lift the tank straight up, about one foot.
    • The tank is attached to the riser main, and the two must be lifted as a unit. Be careful and get help, as this can be very heavy.
  32. India Mark II Riser Main (Tripod) Replacement: 手順 32、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 32、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 32、 3の画像 3
    • Have a third person place the pipe vise around the riser main, on top of the top flange.
    • Tighten the pipe vise securely around the riser main.
  33. India Mark II Riser Main (Tripod) Replacement: 手順 33、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 33、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 33、 3の画像 3
    • Secure the pipe vise to the top flange with two bolts and nuts to hold the pipe vise in place.
  34. India Mark II Riser Main (Tripod) Replacement: 手順 34、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 34、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 34、 3の画像 3
    • Unscrew the tank from the riser main.
  35. India Mark II Riser Main (Tripod) Replacement: 手順 35、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 35、 2の画像 2
    • Lift the tank up a few inches above the top of the riser main.
  36. India Mark II Riser Main (Tripod) Replacement: 手順 36、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 36、 2の画像 2
    • Insert the rod vise between the riser main and the tank, around the pump rod.
    • Tighten the rod vise onto the pump rod.
  37. India Mark II Riser Main (Tripod) Replacement: 手順 37、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 37、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 37、 3の画像 3
    • Unscrew the T-handle from the pump rod and remove it.
    • Keep the T-handle ready to reattach to the pump rod after the tank is removed.
  38. India Mark II Riser Main (Tripod) Replacement: 手順 38、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 38、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 38、 3の画像 3
    • Remove the tank.
  39. India Mark II Riser Main (Tripod) Replacement, Riser Main Coupling: 手順 39、 2の画像 1 India Mark II Riser Main (Tripod) Replacement, Riser Main Coupling: 手順 39、 2の画像 2
    • Place a coupling over the pump rod, on top of the rod vise.
  40. India Mark II Riser Main (Tripod) Replacement: 手順 40、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 40、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 40、 3の画像 3
    • Reattach the T-handle to the top of the pump rod.
  41. India Mark II Riser Main (Tripod) Replacement: 手順 41、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 41、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 41、 3の画像 3
    • Loosen and remove the rod vise from the pump rod.
    • The coupling will drop down onto the riser main.
  42. India Mark II Riser Main (Tripod) Replacement: 手順 42、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 42、 2の画像 2
    • Screw the coupling onto the end of the riser main.
    • Use a pipe wrench to tighten the coupling onto the riser main.
  43. India Mark II Riser Main (Tripod) Replacement, Riser Main: 手順 43、 3の画像 1 India Mark II Riser Main (Tripod) Replacement, Riser Main: 手順 43、 3の画像 2 India Mark II Riser Main (Tripod) Replacement, Riser Main: 手順 43、 3の画像 3
    • Lower the tripod pipe vise to the top of the riser main.
    • Close the tripod pipe vise around the riser main, and lock it shut.
  44. India Mark II Riser Main (Tripod) Replacement: 手順 44、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 44、 2の画像 2
    • Tighten the tripod pipe vise.
  45. India Mark II Riser Main (Tripod) Replacement: 手順 45、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 45、 2の画像 2
    • This procedure requires an important communication dialog between the rope operator and the pipe vise operator.
    • The rope operator's job is to pull hard on the rope to take up the slack, and announce that they've "got it," to let the vise operator know that they're holding the weight of the riser main.
    • The vise operator will then announce "loosening," and loosen the pipe vise.
  46. India Mark II Riser Main (Tripod) Replacement: 手順 46、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 46、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 46、 3の画像 3
    • With the pipe vise loosened, pull the riser main up out of the well.
    • Pull only as high as the tripod vise operator can comfortably reach.
  47. India Mark II Riser Main (Tripod) Replacement: 手順 47、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 47、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 47、 3の画像 3
    • The pipe vise operator then announces "tightening," and tightens the pipe vise.
    • It is now safe to loosen and remove the tripod pipe vise.
    • Be sure to loosen and then fully remove the tripod pipe vise from the riser main. Sliding it down the riser main will scratch the pipe, creating dangerous sharp grooves and causing rust.
  48. India Mark II Riser Main (Tripod) Replacement: 手順 48、 2の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 48、 2の画像 2
    • Lower the tripod pipe vise down to the bottom of the exposed section of riser main pipe.
  49. India Mark II Riser Main (Tripod) Replacement: 手順 49、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 49、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 49、 3の画像 3
    • Secure the tripod pipe vise to the riser main pipe and tighten it securely.
  50. India Mark II Riser Main (Tripod) Replacement: 手順 50、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 50、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 50、 3の画像 3
    • Repeat the lifting procedure: loosen the pipe vise and pull on the rope to raise the riser main another few feet.
  51. India Mark II Riser Main (Tripod) Replacement: 手順 51、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 51、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 51、 3の画像 3
    • The tripod has an indentation built into its top to guide the riser pipe.
    • As you're raising the riser pipe, guide it into the indentation.
  52. India Mark II Riser Main (Tripod) Replacement: 手順 52、 3の画像 1 India Mark II Riser Main (Tripod) Replacement: 手順 52、 3の画像 2 India Mark II Riser Main (Tripod) Replacement: 手順 52、 3の画像 3
    • Lift the riser pipe until the first coupling clears the pipe vise.
    • You will need to open the pipe vise wider to accommodate the coupling.
    • Once the coupling is through the pipe vise, tighten the pipe vise.
    • Be sure to raise the riser main pipe high enough that you can attach the tripod pipe vise to the section of pipe beneath the coupling.
    • From here we have pictures for loosening a coupling with the tripod?
終わりに
作成者
3人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
499,703 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
141 メンバー
16,239のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 487
