メインコンテンツにスキップ
InFocus X2 Lamp Replacement
必要な工具と部品
  1. InFocus X2 Lamp Replacement, Open the Lamp Door: 手順 1、 3の画像 1 InFocus X2 Lamp Replacement, Open the Lamp Door: 手順 1、 3の画像 2 InFocus X2 Lamp Replacement, Open the Lamp Door: 手順 1、 3の画像 3
    • Be sure that the projector is turned off, unplugged, and has cooled for at least 30 seconds.
    • Insert the Jimmy into one of the two notches on the lamp door's top edge.
    • Then use light force on the Jimmy to pry the latch away from the door.
    • If necessary, insert the Jimmy into the second latch and separate it from the projector.
    • Remove the door away from the projector by hand.
  2. InFocus X2 Lamp Replacement, Disconnect the Lamp: 手順 2、 3の画像 1 InFocus X2 Lamp Replacement, Disconnect the Lamp: 手順 2、 3の画像 2 InFocus X2 Lamp Replacement, Disconnect the Lamp: 手順 2、 3の画像 3
    • Gently disconnect the lamp from the projector by using your thumb and forefinger to pinch on the white tab on the plug.
    • Then pull the plug away from the projector.
  3. InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: 手順 3、 3の画像 1 InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: 手順 3、 3の画像 2 InFocus X2 Lamp Replacement, Unscrew the Lamp from the Projector: 手順 3、 3の画像 3
    • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
    • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
  4. InFocus X2 Lamp Replacement, Remove the Old Lamp: 手順 4、 1の画像 1
    • Pull on the bottom plastic tab and remove the lamp by hand.
  5. InFocus X2 Lamp Replacement, Insert the New Lamp: 手順 5、 1の画像 1
    • Insert the replacement lamp into the projector.
終わりに
Caution: The old bulb contains mercury. Please recycle it in a safe and appropriate manner. Look for your local recycling information at https://earth911.com/
添付文書
作成者
1人の作成者と共同作成されました。
Paulina Duarte
メンバー登録日: 09/19/13
553 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2013人のメンバー
UMASSD-GULBRANDSEN-F13S1G3
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 715
