メインコンテンツにスキップ
InFocus Screenplay 4805 Motherboard Replacement
必要な工具と部品
  1. InFocus Screenplay 4805 Motherboard Replacement, Top Panel: 手順 1、 3の画像 1 InFocus Screenplay 4805 Motherboard Replacement, Top Panel: 手順 1、 3の画像 2 InFocus Screenplay 4805 Motherboard Replacement, Top Panel: 手順 1、 3の画像 3
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
  2. InFocus Screenplay 4805 Motherboard Replacement: 手順 2、 2の画像 1 InFocus Screenplay 4805 Motherboard Replacement: 手順 2、 2の画像 2
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
  3. InFocus Screenplay 4805 Motherboard Replacement: 手順 3、 3の画像 1 InFocus Screenplay 4805 Motherboard Replacement: 手順 3、 3の画像 2 InFocus Screenplay 4805 Motherboard Replacement: 手順 3、 3の画像 3
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
  4. InFocus Screenplay 4805 Motherboard Replacement: 手順 4、 1の画像 1
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
  5. InFocus Screenplay 4805 Motherboard Replacement: 手順 5、 1の画像 1
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
  6. InFocus Screenplay 4805 Motherboard Replacement, Motherboard: 手順 6、 3の画像 1 InFocus Screenplay 4805 Motherboard Replacement, Motherboard: 手順 6、 3の画像 2 InFocus Screenplay 4805 Motherboard Replacement, Motherboard: 手順 6、 3の画像 3
    • Using the Phillips #1 screwdriver, remove the (4) four 1.5 cm screws on each of the four corners of the motherboard cover.
    • Remove the white tab connected to the light bulb.
  7. InFocus Screenplay 4805 Motherboard Replacement: 手順 7、 3の画像 1 InFocus Screenplay 4805 Motherboard Replacement: 手順 7、 3の画像 2 InFocus Screenplay 4805 Motherboard Replacement: 手順 7、 3の画像 3
    • Gently pull the white tab on the right side of the silver power housing by pinching each side of it.
    • Pinch the two black tabs on the inside of the cover to remove.
    • Gently pull on the long white tab to remove it.
終わりに
作成者
3人の作成者と共同で作成されました。
Marilyn Urness
メンバー登録日: 09/28/17
671 ポイント
6のガイドは作成済み
チーム
Eastern Washington University, Team S2-G3, Crane Fall 2017 Eastern Washington University, Team S2-G3, Crane Fall 2017人のメンバー
EWU-CRANE-F17S2G3
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 444
