はじめに
Replace the built-in 2.5 watt mono speaker if you are experiencing sound problems.
For this project you will need a torx screwdriver and metal spudger. You may need a can of compressed air to clean the inside of the projector.
必要な工具と部品
Flip the projector on its back.
Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
Locate the circle speaker on the lower left corner of the inside of the lid.
Use the Phillips #1 screwdriver to remove the three gold 2cm gold screws.
Remove the speaker from the lid and flip metallic side down.
