メインコンテンツにスキップ
InFocus Screenplay 4805 Mono Speaker Replacement
必要な工具と部品
  1. InFocus Screenplay 4805 Mono Speaker Replacement, Top Panel: 手順 1、 3の画像 1 InFocus Screenplay 4805 Mono Speaker Replacement, Top Panel: 手順 1、 3の画像 2 InFocus Screenplay 4805 Mono Speaker Replacement, Top Panel: 手順 1、 3の画像 3
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
  2. InFocus Screenplay 4805 Mono Speaker Replacement: 手順 2、 2の画像 1 InFocus Screenplay 4805 Mono Speaker Replacement: 手順 2、 2の画像 2
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
  3. InFocus Screenplay 4805 Mono Speaker Replacement: 手順 3、 3の画像 1 InFocus Screenplay 4805 Mono Speaker Replacement: 手順 3、 3の画像 2 InFocus Screenplay 4805 Mono Speaker Replacement: 手順 3、 3の画像 3
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
  4. InFocus Screenplay 4805 Mono Speaker Replacement: 手順 4、 1の画像 1
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
  5. InFocus Screenplay 4805 Mono Speaker Replacement: 手順 5、 1の画像 1
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
  6. InFocus Screenplay 4805 Mono Speaker Replacement, Mono Speaker: 手順 6、 2の画像 1 InFocus Screenplay 4805 Mono Speaker Replacement, Mono Speaker: 手順 6、 2の画像 2
    • Locate the circle speaker on the lower left corner of the inside of the lid.
    • Use the Phillips #1 screwdriver to remove the three gold 2cm gold screws.
    • Remove the speaker from the lid and flip metallic side down.
  7. InFocus Screenplay 4805 Mono Speaker Replacement: 手順 7、 2の画像 1 InFocus Screenplay 4805 Mono Speaker Replacement: 手順 7、 2の画像 2
    • Gently pull the white connector to release the speaker.
    • Lift the speaker out of its holding.
終わりに
作成者
4人の作成者と共同で作成されました。
Marilyn Urness
メンバー登録日: 09/28/17
671 ポイント
6のガイドは作成済み
チーム
Eastern Washington University, Team S2-G3, Crane Fall 2017 Eastern Washington University, Team S2-G3, Crane Fall 2017人のメンバー
EWU-CRANE-F17S2G3
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 171
