メインコンテンツにスキップ
InFocus LP435Z DLP Board Replacement
必要な工具と部品
  1. InFocus LP435Z DLP Board Replacement, External Shell: 手順 1、 2の画像 1 InFocus LP435Z DLP Board Replacement, External Shell: 手順 1、 2の画像 2
    • Place the projector on its back (buttons down) with the lens facing away from you.
    • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
    • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
  2. InFocus LP435Z DLP Board Replacement: 手順 2、 2の画像 1 InFocus LP435Z DLP Board Replacement: 手順 2、 2の画像 2
    • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
    • There is no lamp assembly in the projector used in this guide, yours may appear different.
  3. InFocus LP435Z DLP Board Replacement: 手順 3、 2の画像 1 InFocus LP435Z DLP Board Replacement: 手順 3、 2の画像 2
    • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
    • Pull the rear plate straight off and set it aside.
  4. InFocus LP435Z DLP Board Replacement: 手順 4、 3の画像 1 InFocus LP435Z DLP Board Replacement: 手順 4、 3の画像 2 InFocus LP435Z DLP Board Replacement: 手順 4、 3の画像 3
    • Flip the projector over and turn around so that the lens faces you.
    • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
    • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
    • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
  5. InFocus LP435Z DLP Board Replacement: 手順 5、 2の画像 1 InFocus LP435Z DLP Board Replacement: 手順 5、 2の画像 2
    • Lift away the top case plate and set it aside.
  6. InFocus LP435Z DLP Board Replacement, DLP Board: 手順 6、 1の画像 1
    • Remove the four T10 Torx 8.5 mm screws holding the DLP board in place.
  7. InFocus LP435Z DLP Board Replacement: 手順 7、 1の画像 1
    • Unplug the small ribbon cable attaching the DLP board to the motherboard.
  8. InFocus LP435Z DLP Board Replacement: 手順 8、 2の画像 1 InFocus LP435Z DLP Board Replacement: 手順 8、 2の画像 2
    • Detach the DLP board from where it is connected to the motherboard by a large 100 pin connector.
    • Pry up gently while wiggling from left to right if needed.
    • The ribbon cable on the other side of the board could break if pulled too hard.
  9. InFocus LP435Z DLP Board Replacement: 手順 9、 2の画像 1 InFocus LP435Z DLP Board Replacement: 手順 9、 2の画像 2
    • Remove the black plastic retaining clip reinforcing the large ribbon cable connector by prying it from the left edge.
    • Gently pry the large ribbon cable connector from the DLP board, and remove the board.
    • Using too much force could damage the connector.
終わりに
3 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Andrew Kennedy
メンバー登録日: 01/29/13
186 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 20-3, Maness Winter 2013 Cal Poly, Team 20-3, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S20G3
4 メンバー
6のガイドは作成済み
コメント 1 件
I Andrew
Recently I bought an INFOCUS LP435Z, it was with the inverted image, when I wanted to use the buttons to enter the menu, to modify the image inversion, none of the buttons reacted.
You will have an idea of what is due and how to solve it? Could it be that with the option of active blocking? I do not have the unlock key, how could I check it?
Thank you very much for your answer.
Regards
Maximiliano - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,273
