メインコンテンツにスキップ
InFocus IN3104 Cooling Fan Replacement
必要な工具と部品
  1. InFocus IN3104 Cooling Fan Replacement, Top Cover: 手順 1、 3の画像 1 InFocus IN3104 Cooling Fan Replacement, Top Cover: 手順 1、 3の画像 2 InFocus IN3104 Cooling Fan Replacement, Top Cover: 手順 1、 3の画像 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Cooling Fan Replacement: 手順 2、 3の画像 1 InFocus IN3104 Cooling Fan Replacement: 手順 2、 3の画像 2 InFocus IN3104 Cooling Fan Replacement: 手順 2、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: 手順 3、 2の画像 1 InFocus IN3104 Cooling Fan Replacement, InFocus IN3104 Metal Cover Disassembly: 手順 3、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. InFocus IN3104 Cooling Fan Replacement: 手順 4、 3の画像 1 InFocus IN3104 Cooling Fan Replacement: 手順 4、 3の画像 2 InFocus IN3104 Cooling Fan Replacement: 手順 4、 3の画像 3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  5. InFocus IN3104 Cooling Fan Replacement, Cooling Fan: 手順 5、 2の画像 1 InFocus IN3104 Cooling Fan Replacement, Cooling Fan: 手順 5、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the three 6 mm screws on the metal cover beside the lamp.
    • The screws are in a tight location, so you may need a thin screwdriver or an extension to remove them.
  6. InFocus IN3104 Cooling Fan Replacement: 手順 6、 3の画像 1 InFocus IN3104 Cooling Fan Replacement: 手順 6、 3の画像 2 InFocus IN3104 Cooling Fan Replacement: 手順 6、 3の画像 3
    • Unplug the yellow, red, and black colored cable bundle from the motherboard.
    • Remove the cooling fan from the device by lifting it out.
終わりに
作成者
4人の作成者と共同で作成されました。
Tae Min Kim
メンバー登録日: 01/24/20
409 ポイント
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 408
