メインコンテンツにスキップ
In-Ground Pool Filter Replacement
必要な工具と部品
  1. In-Ground Pool Filter Replacement, Filter: 手順 1、 2の画像 1 In-Ground Pool Filter Replacement, Filter: 手順 1、 2の画像 2
    • Make sure the pool pump switch is off.
  2. In-Ground Pool Filter Replacement: 手順 2、 3の画像 1 In-Ground Pool Filter Replacement: 手順 2、 3の画像 2 In-Ground Pool Filter Replacement: 手順 2、 3の画像 3
    • Unscrew the metal ring bracket that is on the filter housing in order to remove the top half of the filter housing (lid). Turn the handle in a counter-clock wise motion until it is completely loose and the screw can be removed.
  3. In-Ground Pool Filter Replacement: 手順 3、 3の画像 1 In-Ground Pool Filter Replacement: 手順 3、 3の画像 2 In-Ground Pool Filter Replacement: 手順 3、 3の画像 3
    • Take the metal ring bracket off.
  4. In-Ground Pool Filter Replacement: 手順 4、 2の画像 1 In-Ground Pool Filter Replacement: 手順 4、 2の画像 2
    • Remove the top half of the filter housing.
  5. In-Ground Pool Filter Replacement: 手順 5、 3の画像 1 In-Ground Pool Filter Replacement: 手順 5、 3の画像 2 In-Ground Pool Filter Replacement: 手順 5、 3の画像 3
    • Remove the O-ring.
  6. In-Ground Pool Filter Replacement: 手順 6、 3の画像 1 In-Ground Pool Filter Replacement: 手順 6、 3の画像 2 In-Ground Pool Filter Replacement: 手順 6、 3の画像 3
    • Unscrew the filter cap in a counter clock wise motion until it comes off.
  7. In-Ground Pool Filter Replacement: 手順 7、 3の画像 1 In-Ground Pool Filter Replacement: 手順 7、 3の画像 2 In-Ground Pool Filter Replacement: 手順 7、 3の画像 3
    • Take the pool filter out and place on the ground. Put the new filter in and to put it all back together you can simply follow these directions in reverse order.
    • While the filter housing is apart, you should inspect the O-ring to determine if it has any cracks or tears. If so, replace it with a new O-ring. If it still appears to be in decent condition, then continue to use it and apply a little lube. NEVER use Vaseline or any other petroleum-based lubricant on pool parts. Look for silicone-based lubes.
終わりに
Every pool has different size filters. This guide is a general reference of how to replace a filter and return the filter back to the pump. To reassemble your device, follow these instructions in reverse order.
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Benjamin Goodman
メンバー登録日: 10/02/16
232 ポイント
1ガイドが承認済み
チーム
Pasco Hernando, Team 5-2, Prince Fall 2016 Pasco Hernando, Team 5-2, Prince Fall 2016人のメンバー
PHSC-PRINCE-F16S5G2
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 37
今までの合計 779
