メインコンテンツにスキップ
In-Ear Headphone Control and Mic Block Disassembly
必要な工具と部品
  1. In-Ear Headphone Control and Mic Block Disassembly, The Control Unit: 手順 1、 1の画像 1
    • Find the edge of the control unit and get a very fine flathead screw driver (or a plastic pry tool which would do less damage)
  2. In-Ear Headphone Control and Mic Block Disassembly, Opening The Unit: 手順 2、 1の画像 1
    • Wedge the tool in the corner and start sliding it to the left.
    • As you do this slowely twist the screw driver back and forth to release the clips.
    • Try not to let the tool slip into the control unit as this may damage the circuit board inside.
  3. In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: 手順 3、 2の画像 1 In-Ear Headphone Control and Mic Block Disassembly, Removing The Cover: 手順 3、 2の画像 2
    • Repeat step 2 and the control unit should open as seen in the image.
    • Remove the plastic sleeves and you will be left with just the circuit board (see second image).
  4. In-Ear Headphone Control and Mic Block Disassembly, Identify Broken Wire: 手順 4、 1の画像 1
    • It is quickly seen that one of the wires has broken away from the circuit board (see image)
  5. In-Ear Headphone Control and Mic Block Disassembly, Resolder the Broken Wire: 手順 5、 1の画像 1
    • Once the wire is found a steady hand and a fine tipped soldering iron should be used to reattach the wire.
    • Ensure that you do not head to circuit board for too long as it may cause damage (be as quick as possible!)
    • After this, the circuit board and wires should be replaced as they were before. Press the plastic cover halves together and it should click back into place.
    • And they are fixed!
終わりに
Your headphones should now be working!
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alexander
メンバー登録日: 09/10/18
269 ポイント
1ガイドが承認済み
2 件のコメント
Thanks a lot this worked perfectly thank you very much
MD Ratul - 返信
Very good lesson. Thanks a lot...
PK Chatterjee - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 21
過去 30 日: 87
今までの合計 15,563
