メインコンテンツにスキップ
Ibanez 5 String Bass Model SR405QM Strings Replacement
必要な工具と部品
  1. Ibanez 5 String Bass Model SR405QM Strings Replacement, Strings: 手順 1、 1の画像 1
    • Loosen all of the strings completely by turning each tuning peg counter clockwise. Continue until there is no tension in the strings
  2. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 2、 1の画像 1
    • Remove each string by pulling it out of the string tree at the top and through the bridge at the bottom.
  3. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 3、 1の画像 1
    • Thread the largest new string through the bridge hole farthest from the knobs. Hold it firmly in place.
  4. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 4、 1の画像 1
    • Pull the string up to the corresponding string tree.
  5. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 5、 1の画像 1
    • Firmly grasp the middle of the string and pull it taut.
  6. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 6、 2の画像 1 Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 6、 2の画像 2
    • On a taut string, measure one inch past the nut before using a pair of wire cutters to cut the string.
  7. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 7、 1の画像 1
    • Take the end of the string and insert it into the hole in the middle of the string tree.
  8. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 8、 1の画像 1
    • Bend the string sideways into the channel of the string tree.
  9. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 9、 1の画像 1
    • Use one hand to maintain tension in the string by grabbing the string and rotating the hand toward the fret board.
    • If tension is not retained it may result in uneven tension in the string tree, causing the tree to break.
  10. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 10、 1の画像 1
    • Rotate the tuning peg counterclockwise until the string is slightly taut, but not tight.
    • Check to ensure that the string is lined up with the proper notch in the nut.
    • You will have proper alignment when the sting bends at a minimum angle.
  11. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 11、 1の画像 1
    • Repeat steps 3-10 for each string.
    • Each string will progressively get closer to the knobs. It is not essential to progress from thick to thin strings, but it is important that they are connected to the proper string tree.
  12. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 12、 1の画像 1
    • Caution: Do not over tighten the strings. This can cause the strings to snap and could cause bodily injury. The strings are too tight when you have difficulty turning the tuning peg.
    • Tighten the string until it is close to the proper tuning. Use an electronic tuner or an online tuner that uses your computer's microphone. (Google: Online Tuner)
    • Note: Clockwise rotation of the tuning peg tightens the string and produces a higher pitch. Counter-clockwise rotation loosens the string causing a lower pitch.
    • Tune the thickest string to B, the second thickest string E, the next thickest to A, the next string to D, and the last string to G.
  13. Ibanez 5 String Bass Model SR405QM Strings Replacement: 手順 13、 1の画像 1
    • Because the strings will change pitch as the guitar body deforms due to increased tension, repeat step 12 after each string is tuned individually.
終わりに
You have successfully replaced and tuned your strings!
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Vincent Nguyen
メンバー登録日: 01/11/13
82 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 5-18, Forte Winter 2013 Cal Poly, Team 5-18, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S5G18
4 メンバー
9のガイドは作成済み
コメント 1 件
Thanks for this, it's very helpful! However, I've always changed strings one at a time for two reasons - 1)keeping the tension on the neck is better than relieving it all at once, and 2) it's easier to tune the string. I usually start with the 1st string (lightest) and work my way up.
fisheromen308 - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 14
過去 30 日: 66
今までの合計 2,830
