Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
The battery is now disconnected.
Open the laptop so that the screen is facing you.
Use a plastic opening tool to pry off the eight plastic screw covers around the display.
Note that there are screw covers on the sides (two on the left and one on the right).
Carefully pry the plastic border away from the screen using the plastic opening tool.
Note that this step requires some force. There are plastic clips that help hold the border in place so do not worry about snapping sounds.
Using a #0 Phillips screwdriver, remove the four 3.25 mm screws
The other two screws are in the same position on the opposite side of the display.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
